Author Topic: CB350/360 starter block off plug, speedo spacers, tach plugs  (Read 45005 times)
Offline Dexxx
Re: CB350/360 starter block off plug, speedo spacers, tach plugs
« Reply #150 on: Apr 13, 2017, 01:59:42 »
PJ dont know if you still check the boards... but sent you a PM.
THanks
Offline crazypj
« Reply #151 on: May 04, 2017, 11:51:35 »
Yep I'm still here, last 6 weeks or so have been totally crazy though, all sorts of stuff going wrong.  :(
 Grandson is 18 months old now, learned to run and thinks it's great fun to play on 'the big kids' equipment over park, keeps doing 'gravity' experiments rolling soccer ball down the 'twirly whirly' slides then goes down after it. I have to use the stairs, lost almost 20lbs in less than 3 months (no, I'm not trying to lose weight)
Still haven't replaced the pipes in 'laundry' but leak is down to a couple of drips and garage has dried out pretty well.
Getting caught up with carbs for 360's, finishing off some starter plugs and still in process of re-building a 360 cylinder head.
Things are going slow but they are still going  ;D
Best thing I ever overheard
Brian Morgan, 1982
Offline crazypj
« Reply #152 on: Jun 20, 2018, 16:10:12 »
Finished 12 pairs of vacuum adapter for 360's. Had a bit of a 'run' on them as 2 months ago I had 23 pairs.Also have 2 starter plugs
Brian Morgan, 1982
Offline Scratcher09
« Reply #153 on: Jul 07, 2018, 11:11:03 »
What is current price for starter plug?
Offline crazypj
« Reply #154 on: Jul 09, 2018, 16:10:01 »
Still $35.00 including shipping lower 48. Canada is about $3.50 more for shipping, rest of world, haven't checked for about 2 yrs but would be at cost. Vacuum adapters still $10.00 pair plus shipping/bubble mailer ($5.00 lower 48)
Brian Morgan, 1982
Offline crazypj
« Reply #155 on: Aug 08, 2018, 18:11:05 »
Just made some alloy handlebar mounts to replace the worn out rubber mounts. If anyone want's some with 12mm hole, $20.00 plus shipping. If you want them to mount LED, will have to have LED size plus make a different method of holding them in place. I think I have a way of doing it.
Brian Morgan, 1982
Offline J-Rod10
    • Slipstream Cycle Works
« Reply #156 on: Aug 09, 2018, 00:43:13 »
Hope these go over well. I've thought about making them, just never took the time to sit down and measure the taper. I sell a ton of them for the XS. That 40 year old rubber is junk.
Best of luck with them!
Offline dwysywd
« Reply #157 on: Mar 07, 2019, 14:05:31 »
I know this is an old thread, Are you still making these starter caps? would these fit CB550?
Offline JonnyHello
« Reply #158 on: Mar 28, 2019, 18:53:59 »
Any chance you still have a tach plug for CB350? Thanks
Offline crazypj
« Reply #159 on: Mar 29, 2019, 19:37:50 »
I usually have one or two part machined and need finishing.
Send a PM if you want one
Brian Morgan, 1982
