Author Topic: Engine inspiration thread!  (Read 168435 times)
Offline quadracer351
Re: Re: Engine inspiration thread!
« Reply #140 on: Jul 10, 2013, 13:05:01 »
quad do not use 1200 on these motors it simply does not get hot enough in operation to cure the paint to a final cure and it will always be very very fragile and will chip like mad, use the 500* use a very light coat of primer, and then base coat it, i do not typically like to use the clear high temps as they just tend to flake, bleach, and chip... i did a full write up a while back on painting a motor if you want to search my name and that.  let me know if i can help.... i like to use an engine cleaner, then non clorine brake cleaner to clean up the motors for paint, super easy and really works great
Yeah I knew it wouldn't cure from engine heat but I have a heat gun that reaches 1375F that I was going to go through the heat cycles with. I also choose the vht flameproof because the red they had plus the clear gave it just about the same red as my frame. I'll try looking more for a closer red in the engine enamel. I only used engine cleaner, brake cleaner, and a rifle bore cleaner brush along with the red scotch brite pads.
Sent from my SCH-I535 using Tapatalk 2
« Last Edit: Jul 10, 2013, 13:22:59 by quadracer351 »
Offline koonendez
« Reply #141 on: Jul 10, 2013, 14:33:03 »
Love the gold engine scheme. Definitely inspired!
Offline duggyb
  • where are the skis?
« Reply #142 on: Jul 22, 2013, 20:22:48 »
Well this thread gave me inspiration to do my own motor hopefully mine can give someone else some more!
CJ360T Motor
Mikuni VM30s
Pods
CB360T Headers
« Last Edit: Jul 22, 2013, 20:26:32 by duggyb »
Offline neevo
    • The blog of my custom CB400F build
« Reply #143 on: Jul 24, 2013, 07:01:46 »
Anyone find that link? My iPhone isn't going far back enough on your posts to find the thread.
See the condensed version of my full build on my blog!
Offline Hoosier Daddy
  • Earache my eye...
« Reply #144 on: Jul 24, 2013, 10:34:01 »
duggyb, I am really digging that engine stand!
You could degrease that bellhousing and use it for all kinds of things, unless you're going to connect a trans to an engine with it. ;)
STAY CLEAN '67 BSA Spitfire
ROCK-IT '81 CB750C
BOMBER '81 GL1100
OVERKILL '80 GS750
NO CLASS '72 CB450 K5
Offline canyoncarver
  • 'hacking is learning'
« Reply #145 on: Jul 24, 2013, 17:14:17 »
Ditto, still looking for it too.  JRK5982 - got a link?
Thanks in advance.  I've noticed quite a bit of your great work posted throughout the forum.
Offline JRK5892
    • The Powder Pro
« Reply #146 on: Jul 24, 2013, 17:20:25 »
here is how i do it...
spray with gunk foaming engine cleaner... scrub with simple green and scrub brush, hose off, by now all the major grime and oil should be gone, 3 cans of non clorinated brake cleaner, wipe down with denatured alchole, light coats of primer, then paint... done
here is the motor i did this weekend
motor clean waiting on paint
i have a large oven but it is not needed just speeds the dry
all done
another motor i did
cleaned and prepped
light primer
painted
done
[/QUOTE]
Joe
"your life is an occasion, Stand up to it"
www.thepowderpro.com
recent builds: Hd street bob, TX cafe, KZ bratt, Goldwing tour, bratt wing, st fighter, road king, vriago bobber, chop, FXD, 1200 sporty, 1200xl sporty, GSXR, Royal enfield.. and more
Offline crazypj
« Reply #147 on: Jul 24, 2013, 21:34:55 »
I was just reading back through some of this and realised aluminium melts around 11~1200f so 1300 VHT wont cure before you end up with a blob on the floor ;D
Best thing I ever overheard
Brian Morgan, 1982
Offline JRK5892
    • The Powder Pro
« Reply #148 on: Jul 25, 2013, 11:15:20 »
100% PJ i only use 500* paint for motors, if you go over that it will not cure and will chip and flake, also when motor paint cures it has much more resistance to chemicals like oil and gas. 500* is the way to go
Joe
Offline cyclhed
    • Irish Cycles
« Reply #149 on: Jul 25, 2013, 13:16:16 »
I like the bottle opener JRB5892 and duggybs motor too!
540cc CB360 Honda engine cafe' Project: http://www.dotheton.com/forum/index.php?topic=39496
CR200 Chopper Project: http://www.dotheton.com/forum/index.php?topic=28969
CL100/SL125 Cafe' Project: http://www.dotheton.com/forum/index.php?topic=36548
SL-350 Super Moto-Sport Project: http://www.dotheton.com/forum/index.php?topic=27751
Twowheelin' since '62!
