Author Topic: Long awaited CB200 Build  (Read 22189 times)
Offline bex
Re: Long awaited CB200 Build
« Reply #120 on: Apr 20, 2018, 13:59:37 »
Itís made specifically for a CB200 actually!
Offline trek97
« Reply #121 on: Apr 20, 2018, 14:08:58 »
Whatís the benefit to having it adjustable?
Offline bex
« Reply #122 on: Apr 20, 2018, 14:25:30 »
The adjustable just refers to being able to position the vent tube to suit your set up.
Offline bex
« Reply #123 on: Apr 25, 2018, 07:04:42 »
What size are the carbs bored to now?
The carbs internals havenít been touched - I bought new carbs (PE22ís) as the originals didnít have enough metal for boring out.
Offline bex
« Reply #124 on: Apr 26, 2018, 06:19:10 »
So the engine work is all finished - head and carbs were the final bits. Engine specialist has done a superb job machining the carbs, some pics below. More to follow at the weekend.
Petrol and heat proof hose to sleeve together:
Iím just waiting for a couple of these to arrive to go over the hoses:
Offline MickyC
« Reply #125 on: Apr 26, 2018, 07:12:14 »
This is epic. What a awesome build. Did you find any other callipers that may have suited front mount?
Offline bex
« Reply #126 on: Apr 26, 2018, 08:24:39 »
You mean the front brake caliper? Nope, I designed the bracket to fit the caliper so I didnít look at any other calipers once I picked that one.
Offline bex
« Reply #127 on: Jun 04, 2018, 06:39:09 »
Almost there with the engine, just got these blasted as I forgot initially.
Sorry for the bad quality engine photo, poor lighting.
Offline Alex jb
« Reply #128 on: Jun 04, 2018, 10:21:09 »
What carbs are you using?
Are you painting the journals black too?
Build is looking good.
Offline bex
« Reply #129 on: Jun 04, 2018, 10:32:37 »
Thanks
They are PE22ís. Which donít fit around my frame of course.
Iím not sure those are called journals are they? You may be right! In any case yes theyíll be painted but Iím not sure about their covers, or the clutch and rotor covers which Iíve left as they were for now while I decide.
