Author Topic: was a rupp roadster, now i dont know what to call it  (Read 26053 times)
Offline Hurco550
Re: was a rupp roadster, now i dont know what to call it
« Reply #130 on: Jul 31, 2017, 16:12:28 »
Looked back and realized that the roadster wasn't like the blackwidow or scrambler, yeah thats totally different.  There is alot of power left in that motor to free up, almost to much.  Pull the governor, get a billet flywheel (the stock one will explode at high RPM), tighter springs, cone filter, exhaust, and throw a mikuni on there so its manageable.  The stock carb turns into an on/off switch at this point and its almost unrideable.  I need to get mine out of the shed
funny man, what you just wrote is my exact plans for the motor, plus I'll probably do a billet con rod while I'm at it. For now it's just a cone filter, jetted carb and pipe... because money, or lack there of lol once I get it together and going ill piece the hop up stuff together as funds become available
~ bradj
Offline JSJamboree
  • DTT BIKE OF 2016
  • Weird Indy Kid
« Reply #131 on: Jul 31, 2017, 16:16:44 »
I cant say enough what a difference the mikuni made. Here is the kit that I put on mine.
http://www.ebay.com/itm/22MM-MIKUNI-CARB-KIT-PREDATOR-212-GX200-GX160-HONDA-CLONE-Drift-Trike-Mini-Bik-/252314674798?hash=item3abf20666e:g:10wAAOSwYlJW4GEm&vxp=mtr
Offline Hurco550
« Reply #132 on: Jul 31, 2017, 16:33:37 »
Yep, I have that saved on my watch list. I think iirc a Yamaha blaster carb is the same size mikuni, and van 2 be had for less coin yet
~ bradj
Offline MotorbikeBruno
    • Carb cleaning in MN
« Reply #133 on: Aug 07, 2017, 22:17:29 »
I love this thread!  8) 8) 8) 8) 8) 8)
Offline XS750AU
« Reply #134 on: Aug 07, 2017, 23:38:14 »
Quote
I have thought about something similar,  but instead of full sheets, maybe some "x" braces in between the vertical ones.
Sorry for not getting back to you sooner. Refer to the attached photo, the top section (red line) is in compression, meaning it is being pushed from both ends.  The current structure is not good in compression, much better in tension (being pulled at the ends). Cross braces also work well in tension but not compression, so I would suggest a solid sheet welded along the red line is the best option, but if you wanted to make some cool cut outs down the middle of the sheet then go up a thickness or 2! The current structure will behave a bit like a house of cards, once it goes it will go quickly.
The orange line is of secondary concern, and would just stiffen up the headstem, so you could cut a few seconds off your lap times  ;D. That area is in tension so cross braces would be OK.
Hope this helps.
Love what you have done so far.
“Engineering is the art of being approximately right rather than exactly wrong.”
Yamaha XS750-2D
Yamaha XS896
Husaberg FE550
Yamaha TT250
Yamaha IT200N
Offline Popeye SXM
  • Also used for MX
« Reply #135 on: Aug 08, 2017, 00:04:02 »
I love this project, but I agree, It could collapse, very quickly, say after a bump or two?
Offline Hurco550
« Reply #136 on: Aug 08, 2017, 11:25:20 »
Hope this helps.
Thanks guys for the input! It really is appreciated. I am not, and do not claim to be an engineer, I'm just a welder that has access to 2d cad software and a waterjet ha. I plan to do a strip on the top and front as described, as well as one for good measure between the two bars of the "hardtail". They wont be just plain strips, they will have a few spots for flared holes as well as slots where I can weld them in to connect to the cross gussets. Even though I did a wood mockup a while back, there are still things that I would change now that I have this one made up and tacked together. But oh well, I will make this one work. Thanks again for the input, it didn't fall on deaf ears!
« Last Edit: Aug 08, 2017, 11:30:13 by HURCO550 »
~ bradj
Offline XS750AU
« Reply #137 on: Aug 08, 2017, 19:14:26 »
Sensational, this is going to be good  ;D
Yamaha XS750-2D
Yamaha XS896
Husaberg FE550
Yamaha TT250
Yamaha IT200N
Offline Hurco550
« Reply #138 on: Dec 01, 2017, 01:38:58 »
The project isn't dead, I just got distracted by other things per the norm. My wife decided that it was time that the mini bike get moved out of the living room, so out to lift it goes. Working on mounting the rear brake caliper. I have a little bit of Lathe work to do, and the rest of the gussets for the frame should get cut on the waterjet tomorrow. More to come
~ bradj
Offline irk miller
« Reply #139 on: Dec 02, 2017, 07:51:46 »
It's weird to lose our smart ass comments from a day ago.  Now we have to come up with more smart ass comments.
