www.Moto-Madness.com
Author Topic: was a rupp roadster, now i dont know what to call it  (Read 19809 times)
Offline ridesolo
  • "Illegitimi non carborundum"
Re: Rupp Roadster. I think I'm to big for this
« Reply #30 on: Sep 12, 2015, 22:31:05 »
Lookin' nice.  I wondered how much I was going to have to open up my brake hubs so they'll fit onto the wheels.  Will have to do it X2 as I'll be putting the front brake back on... still toying w/ the idea of doing a front disc, though.  They've got a nice little caliper over at Glenn's that's about right or I know there'd be one from the front of a smaller 4-wheeler available on eBay.
What size sprocket do you have on the jack shaft?  Mine's got a 10 tooth, thinking about maybe changing to a 12 or maybe even 14 tooth.  I figure that little 4hp Tecumseh should be ok after the rebuild, but it's 45 years old and maybe if it's geared a little higher riders won't feel the need to have the thing running at such high RPMs... (yeah right!)
“Fight on and fly on to the last drop of blood and the last drop of fuel, to the last beat of the heart.”
— Baron Manfred von Richthofen
Please check out:  http://www.VetTix.org
These are on a low simmer out in the shop:
'75 Honda CL360: http://www.dotheton.com/forum/index.php?topic=56547.0
'70 Rupp Roadster: http://www.dotheton.com/forum/index.php?topic=67459.0
Offline Hurco550
« Reply #31 on: Sep 14, 2015, 10:21:02 »
I think I could assist in opening those up if you need, and there will also likely need to be more mounting holes added to fit your new wheels (of course you could get lucky and they be the same =)
I will have to count the teeth. Mine is set up for a 35 chain and I believe yours is a 40, so it wont be the same regardless. Mine did come with a 40 sprocket for the front too, and ill count and let you know. I may waterjet a #40 sprocket for the back to have a little stiffer setup =)
~ bradj
1973 Ironhead Hardtail: http://www.dotheton.com/forum/index.php?topic=68135.msg788081#msg788081
"much ingenuity with a little money is more profitable and amusing than much money without ingenuity" - Arnold Bennett
Offline ridesolo
« Reply #32 on: Sep 14, 2015, 16:30:41 »
The difference may be in the year because I just took the front wheel off and the brake drum off it and that drum just slides right onto the new wheel, pretty as you please.  I will have to put new holes into the drums to match up w/ the holes in the wheels, but that shouldn't be too difficult.
I was talking about the number of teeth on the front sprocket.  It looks like the thing has #35 chain but maybe I'm wrong.  The '70 was sort of an odd duck;  it has the new frame style but had 10" wheels so maybe they went to different chain when they went to the 12" wheel.
Offline Hurco550
« Reply #33 on: Sep 16, 2015, 10:07:14 »
sounds like you lucked out. The rear sprocket and drum that I got was some NOS manx cat or something like that, so I knew the odds of it fitting were slim lol
I was looking at yours when I was there the other day, and im pretty sure that your chain is heavier than a 35. I have a chunk of 35 sitting here if you wanna compare =)
~ bradj
Offline Hurco550
« Reply #34 on: Jan 18, 2016, 14:13:23 »
So this now could have been 3 separate build threads, but oh well. Found a $75 complete mini bike on cl. Couldn't pass it up. Got it home, and after a few laps around the yard, my wife decided that I had bought her a new mini bike. Truth be told, seeing her on two wheels made me smile pretty hard, so it's hers now lol.
Didn't take me long to figure out that 2 h.p. isn't enough, so 6.5 should do the trick
~ bradj
Offline canyoncarver
  • 'hacking is learning'
« Reply #35 on: Jan 18, 2016, 14:59:37 »
Big yes!!!
KZ400 The Rabbit
YZF750/1000R The Fly
KZ 750 Twin
ZRX 1100
65 Norton, My damn Shovelhead chop
more YZF750R's, the KZ's, a Zephyr750...and the unfinished 75' CB550 cafe.
Offline ridesolo
« Reply #37 on: Jan 18, 2016, 17:47:17 »
That looks like a good one.
Offline MotorbikeBruno
    • Carb cleaning in MN
« Reply #38 on: Jan 18, 2016, 18:18:25 »
That a boy! She looks quite happy on it! Nice score!
Offline Hurco550
« Reply #39 on: Jan 18, 2016, 20:29:38 »
~ bradj
