Author Topic: Rickman CR Refresh - Collection of Kit Parts  (Read 5478 times)
Offline slikwilli420
« on: Feb 01, 2016, 15:54:43 »
Alright, so I'm a sucker for punishment and when opportunity knocks, you answer! There was a member on the SOHC/4 forum that was going a different direction with his Rickman project and I had a chance to buy the leftovers. In addition to what is shown here I also got the front mud guard and the chain guard.
There is very little information on the specifics of the kit or about reconditioning these parts that I could find. I will use this as a place to document progress on the restoration of these parts but also add details that one could not find without handling these parts.
It seems this is the earlier of kits in that it has the aluminum hubs with Borrani rims, whereas later kits had Ronal 5-spoke mag wheels.
Here is the rear wheel. Both sides of the hub have similar dimensions and the bolt pattern is the same, although the sprocket side is offset further from centerline. Both sides fasteners came apart really easily with some judicious PB Blaster use.
Front wheel has the same bolt pattern for the rotor as the rear rotor and sprocket. The front cast iron rotor is clearly larger than the rear but of the same design. I have gathered that these parts were very likely made for Rickman by Girling. This is the single disc hub version.
Aside from some surface rust, the rotors are both in very good shape. I am hoping I can get them resurfaced enough to get rid of any pitting on the pad surface. The sprocket is in very good condition and looks like it was used very little. It will still be replaced but at least I have something to take dimensions from.
An original set of Tommaselli clipons, in 38mm. While not part of the kit, they will look the part on this build and are a rare vintage part in their own right.
Original CP 2292 rear master cylinder. Its missing the cap but they are still available. The rebuild kits are still out there as well.
The rear caliper stay. I have seen a few permutations of this part, some with holes (likely not factory). Most are this variety, but I have seen some with shorter torque arms that are under the rotor instead of on top.
Front and rear calipers. These are the original CP 2195 units. You can see both are the same 'hand' version. If this were a dual disc version, the second front caliper would have the brake line input on the opposite end of the outer side. I am having some issues getting the second piston out of each caliper. I was able to get one loose with compressed air but the other is very stuck. I will have to adapt a fitting for a grease gun and see if that works. In the meantime, I will keep soaking the piston area with PB Blaster to try and loosen it up.
38mm Betor forks. This is the single disc version. From research I have done, the 38mm street version may have been the single disc one while any Rickman with dual disc was the 41.5mm fork. If anyone can shed light on this it would be really helpful. These will need complete rebuilding top to bottom. I will also eventually be sending the lowers to Jim F to be laser welded as there are some pretty big dings in them. These are also substantially (about 3") shorter than other forks of the era so I may end up sourcing some longer tubes, but that all depends on what frame I use and the desired geometry.
The top and bottom triple trees are the worst of any of the parts for condition. They appear extremely corroded, to the point that they have blistered and pieces are falling off. I think these are beyond saving but opinions are welcome.
That's all for now and as I get parts sourced to rebuild these components I will post here. I will also be leaning on the brothers here for a multitude of services to get everything as new where possible.
Offline Chuck78
    • my bike photo album
Re: Rickman CR Refresh - Collection of Kit Parts
« Reply #1 on: Feb 02, 2016, 22:05:56 »
Oh wow, please excuse me while I wipe the drool off my chin....
I've been looking for a set of those Rickman wheels for many months, you beat me to it!  I was really hoping to find a dual disc set, but as it is now, my Rickman build is going to work pretty well with a set of dual disc Suzuki GS hubs which are a shoe-in for my 1990's fork and dual disc upgrades.  I'm still drooling over those wheels, by the way.  I'd nearly kill for a set of those hubs alone.
As far as the forks, I was told that the "Rickman Betor forks were incorrectly called 41mm but are actually 1-5/8" (word from a Rickman owner), and that the eariler single disc version was the more high performance oriented version with it's thicker fork tubes etc. The 38mm Rickman dual disc forks (Made by MP someone told me, I think that was the name) were the later version.
Yes you are correct that those forks are much shorter than most forks of that period, or even 1990's RSU conventional forks. That is the trouble I am running into trying to drop the front on mine to increase the rake - the Rickman frame is designed around an incredibly short fork.
« Last Edit: Feb 05, 2016, 20:54:34 by Chuck78 »
'77 GS750 920cc, 4-1, GS1100E swinger, 18" Sun rims, Fox Factory Shox, twinpot dual disc, CR31, Yosh cams
'74 Rickman VR250MX
'99 Kawasaki KDX220 rugged terrain ripper
PROJECTS:
'77 Suzuki PE250B
"Pure Enduro" trail beast, ported, Wiseco, TüBliss, Fox Factory Shox/RaceTech
'76 Rickman CR GS1000-1120cc roadracer, Yosh cams&4-1, RF900R fork, Works piggybacks
'79 GS425 489cc Formula 500 racer, Tempter cams, GS650 forks, twinpot brakes, DID rims, GS1100E swinger, Fox Factory Shox
'77 GS550's 650-740cc susp&brake mods
Offline Chuck78
« Reply #2 on: Feb 02, 2016, 22:28:58 »
Too bad you didn't beat me to my Rickman frame and misc parts score, there would be one more semi-original Rickman project being built!  Combining my frame/swinger/rearsets/seat/tank with the parts you have would work quite well together.
Not sure what your plans are, but I'll keep my eyes peeled for a Rickman frame for you.  Geeto67 here in Columbus OH has one (CR750 frame), but the frame and his hoard of most of his cool bikes are all in his hometown 500 miles away in storage with his family. He has no swingarm or parts for it. I have a spare swingarm custom made for the Rickman frame I have (Dresda style), tig welded box section cromoly.
Tom at the Rice Paddy (owner of this awesome Columbus Ohio vintage japanese parts warehouse-salvage business) has a CR900 frame with a few Rickman parts (early style fiberglass gas tanks, seat pan, slightly torqued/twisted early version Rickman swingarm). He had a friend bugging him about buying the Rickman stuff, and he was considering selling it since he knew it'd go to a great home, but he has been keeping it as one of his projects in the distant future while he waits it out to find more parts for it.  Wouldn't hurt to bug either of those guys if you were trying to find a home for those parts. The only other one I have seen was on raresportbikesforsale.com and mentioned that the price the seller was asking was very steep.
Including a spare GS425 engine, and 2 neglected GS1100E box aluminum swingarms, I gave I think $1150 for my wrecked/repaired/gusseted&braced/GS1100E-engine-mounts modified neglected rusting frame and some Rickman parts. The frame was left bare steel where all the gussets, braze joint repairs, and additonal GS engine mounts were fillet-brazed on, and the bare steel left to surface rust for 15 years after the owner/builder died, in a semi truck trailer at the speed shop/vintage bike salvage yard Rockdale Cycles in Georgia.
Parts included were morris rear mag, Rickman rear sprocket, Rickman rear rotor, speedo drive adapter, rear axle, swingarm and pivot shaft, complete rear brake setup, a few engine mount plates, mostly complete rickman black rearsets, extra nickel plated brake pedal, extra nickel plated shifter pedal missing linkage that fits different Rickman rearsets than mine, reverse shift  Rickman shifter (like a Suzuki/Kawasaki non-linkage'd factory shifter flipped backwards/upside down mounted straight to engine shift shaft), recovered by Corbin Rickman solo seat w/o fiberglass tail section pan, Rickman solo seat long stretched steel inner fuel tank missing the fiberglass bodywork cover. I left the ninja front wheel and 38mm forks in Georgia, no room in the truck with 2 dogs camping gear and 14 GS1100E swingarms (12 for the Rice Paddy)!
« Last Edit: Feb 02, 2016, 23:41:56 by Chuck78 »
'74 Rickman VR250MX
PROJECTS:
'77 Suzuki PE250B
Offline Chuck78
« Reply #3 on: Feb 02, 2016, 22:33:00 »
Inversely, if you wanted to flip all that stuff, the two leads on frames not really for sale but slight chance of, well those guys could use all the parts you have! I'd even consider the front wheel and fork, would have jumped on those parts a month or three ago if I had seen them for sale.  I'm not sure if Columbus Kerry aka Geeto67 is on DTT, but I know he is on CafeRacer.net and probably the sohc4 forum.
'74 Rickman VR250MX
PROJECTS:
'77 Suzuki PE250B
« Reply #4 on: Feb 02, 2016, 23:30:45 »
Sorry Chuck I'm saving all of this stuff for another build. Since you are going more modern on your build if there are any leftover Rickman pieces you don't need please keep me in mind.
Offline Chuck78
« Reply #5 on: Feb 02, 2016, 23:50:24 »
Well as it is, the only parts that I may be parting with are the Morris rear mag + Rickman rear sprocket with Rickman specific rear wheel speedo drive adapter,  and the hub mounted adapter to bolt the rotor onto.  Do you have a build in mind yet that you are saving these parts for, or are you just planning to get a project to use them on?  Always keep me in mind on the wheels and also forks if you EVER consider getting rid of them, PLEASE!
I see you mentioned possible resurfacing of your Rickman rotors.  Is this possible in a typical automotive brake lathe?  the outer edge on both sides of mine are a bit chewed up, and I wouldn't mind cleaning it up and losing some extra ounces to boot!
'74 Rickman VR250MX
PROJECTS:
'77 Suzuki PE250B
Offline Chuck78
« Reply #6 on: Feb 03, 2016, 11:57:40 »
I am also exploring places for brake lines like the originals. I have not come up with anything and at this point might be out of luck. Here is what the original fittings look like.
Matt,
Aeroquip still sells the original fittings as they are still quite viable in the hydraulic/brake/automotive air conditioning fields., and Russell makes identical fittings.
There are 3 lines on ebay now for $45 each from a seller with a TON of NOS Rickman parts, seller is in Oregon and has 5-7 different Rickman categories in their store. I think the name is cyclesavant. I almost snagged 1 or 2 of the lines last night but then I realized Jeg's sells the exact fittings and line new for about the same price ($15/fitting, $20/6' -3an line - I think -3an is the size, but maybe -4 thinking back on my Earl's AN fittings that seem slightly smaller).
One on ebay was 14.5" and had a 90 degree end in one side and looks to be crimped fittings, the other 2 had the reusable fittings (do they require a new compression ring on each re-use?) and are 15" & 19" with straight ends.
'74 Rickman VR250MX
PROJECTS:
'77 Suzuki PE250B
« Reply #7 on: Feb 03, 2016, 12:20:18 »
Links to the fittings chuck?
Offline Chuck78
« Reply #8 on: Feb 03, 2016, 12:34:04 »
Mine that came with the Rickman / AP-Lockheed brakes are Aeroquip braided stainless line & fittings like the others I saw on ebay from cyclesavant.
Here is the exact style of Rickman line that came with my Rickman rear AP Lockheed brake (Aeroquip brand fittings):
« Last Edit: Feb 05, 2016, 20:55:29 by Chuck78 »
'74 Rickman VR250MX
PROJECTS:
'77 Suzuki PE250B
Offline Chuck78
« Reply #9 on: Feb 05, 2016, 21:04:52 »
'74 Rickman VR250MX
PROJECTS:
'77 Suzuki PE250B
