www.Moto-Madness.com
OUR ADS ARE FROM SUPPORTERS OF THE COMMUNITY - CONSIDER TURNING YOUR AD-BLOCKER OFF FOR WWW.DOTHETON.COM :)
Author Topic: First build ever  (Read 11675 times)
Offline HDJ80
Re: First build ever
« Reply #80 on: Jun 15, 2017, 02:44:37 »
I kinda like it as is...  Clear coat the frame.
Peter
Peter
2015 Ducati Scrambler - Classic
1981 GSX1100
Offline onefromexile
« Reply #81 on: Jun 15, 2017, 17:33:50 »
I do like the raw metal look
If I can get it pretty clean
I might try to heat  up (blue ) around the welds with a torch and this metal dye I've been wanting to try
That might be a cool look
For frame
« Reply #82 on: Jun 25, 2017, 22:41:19 »
Did a lil more welding on the rear and started the bondo
I'm not powder coating
I'm doing all my own work so I'm gonna do paint too
I'm not the greatest not the worst   Sometimes a lil made it nice cause had to do it twice lol  but if I take my time it comes out great
Haven't sanded bondo yet just testing on the rear hoop
I got more sanding and cleaning on rest of frame before I bondo my creases and primer but it's a start
« Reply #83 on: Jun 25, 2017, 22:44:51 »
Also wanted to post pics of some motor bling
Just finished up all the work and blasting ect
I got over 25 hours alone in dremel and hand sanding filing polishing
« Reply #84 on: Jun 25, 2017, 22:48:32 »
Here is shots of the inside work on the intakes
First I cleaned up the casting lines and crude took very lil because was told 360's have great intake
Kept a rough like 120
I port matched as best I could they measure within a few thou of each other
« Reply #85 on: Jun 25, 2017, 22:53:46 »
Exhaust side got opened up
Substantially
Got more advice on how to shape and what to remove
Also got Schumann motorworks bronze valve guides I'll be installing next
I did not deck my head at all it was flat already after stoning
Used a $20,000 CMM inspection machine at work to check measurements
Overkill
« Reply #87 on: Jun 26, 2017, 01:13:28 »
Yeah I really got my fingers crossed for a bad little ripper
I got bored to gs850 Pistons
not going to get a cam and explore the whole heavy valve springs and eat my head   Bearing journals
But besides that
Did all the recommended mods and it should have better performance and will sound killer less restricted
Wondering if custom headers that have bigger I.d over stock would really help that much more
Cause these stock pipes are pretty small and there is room with the design of the collars to go fatter
Online irk miller
« Reply #88 on: Jun 26, 2017, 07:59:25 »
Depends on what carbs you're using.  The CV carbs will benefit from a longer, narrower exhaust.
« Reply #89 on: Jun 26, 2017, 10:06:42 »
I'll be running stock carbs
Done up by pj
He and a few others talked me into it
Dtt the best
