www.Moto-Madness.com
Author Topic: Project "El Chivo"  (Read 2850 times)
Offline Jachana
    • 1980 CM400
Re: Project "El Chivo"
« Reply #10 on: Oct 25, 2016, 11:01:55 »
Thanks Guys, much appreciated.
Has anyone had the problem of the plunger spinning in the fork tube when trying to remove the lower allen head bolt to take it all apart?
Any special idea or tool that can help?
TIA,
Jachana
1980 CM400 Cafe
1976 Goldwing "Goldfinger"
1973 RT3 360 Resto
1973/77 RT3 "El Chivo"
Offline HerrDeacon
« Reply #11 on: Oct 25, 2016, 11:21:44 »
I usually keep the forks all intact so that the spring pushes down enough to stop it from moving.
Perry
1972 Honda CB350 K4 / 1978 Honda XL250S /1982 Honda MB5 / 2014 Honda CB500X
Offline Jachana
    • 1980 CM400
« Reply #12 on: Oct 25, 2016, 12:09:11 »
Ah yes! its always a simple solution, I will give that a try. Thanks for the input. The first one came apart with ease but the second one not so much.
Jachana
1980 CM400 Cafe
1973 RT3 360 Resto
Offline Jachana
    • 1980 CM400
« Reply #13 on: Oct 26, 2016, 14:23:30 »
Got the rims on and the forks in and lowered as mentioned before. Thank you Yamaha for providing a top spacer lol.
Also Marvel Mystery Oil is awesome as cleaning agent on aluminum.
TIA,
Jachana
1980 CM400 Cafe
1973 RT3 360 Resto
Offline Jachana
    • 1980 CM400
« Reply #14 on: Dec 19, 2016, 12:34:59 »
Just quick update,
Got a ton of parts in. The motor is ready for paint and to be put together. Exhaust from Circle F came and looks amazing. Got some new Shinko's on the rims.
Getting closer,
Jachana
1980 CM400 Cafe
1973 RT3 360 Resto
Offline Jachana
    • 1980 CM400
« Reply #15 on: Jan 03, 2017, 11:23:24 »
Got the monoshock frame tabs cut out and tack'd into place. Still need to finish weld it but its strong. Seat height is very nice.
Got some spacers to add to keep the shock from moving side to side.
Almost ready for powder coat.
Jachana
1980 CM400 Cafe
1973 RT3 360 Resto
Offline Jachana
    • 1980 CM400
« Reply #16 on: Aug 15, 2017, 11:53:02 »
powder coat
1980 CM400 Cafe
1973 RT3 360 Resto
Offline Jachana
    • 1980 CM400
« Reply #17 on: Aug 15, 2017, 11:54:09 »
putting it back together.
1980 CM400 Cafe
1973 RT3 360 Resto
Offline VonYinzer
« Reply #18 on: Aug 15, 2017, 13:13:48 »
Very cool. Makes me want to dive into my DT250 project after my chopper is done. Keep the updates coming!
Offline Jachana
    • 1980 CM400
« Reply #19 on: Aug 16, 2017, 11:24:34 »
Thanks Von, I appreciate it. Check out Giancarlo's dt250 he just finished. Its awesome!
1980 CM400 Cafe
1973 RT3 360 Resto
