Author Topic: 75 CB360 - bad omen "yatagarasu" build  (Read 36728 times)
Offline crazypj
« Reply #230 on: May 08, 2018, 12:01:53 »
'Most' washers are not precision ground.
Try McMaster -Carr for a thrust washer. Pretty sure it's a common inch size.
Only problem I see is you may have to buy a 10 pack although I'm sure other 360 owners would buy one if different size to what they already have as Honda only listed two sizes
Best thing I ever overheard
Brian Morgan, 1982
Offline MiniatureNinja
« Reply #231 on: May 08, 2018, 12:22:12 »
there are two sizes honda makes, 1mm and 1.1mm - I think the 1mm will still allow me to be within tolerance, but 1.1 would be much more in the middle.
I found the 1mm version on eBay - NOS for only 13$ shipped so I'll get that, and hunt around for a 1.1mm if I don't find it by the time this all needs to go together next Sunday I'll just use the 1mm
I also found an NOS cam on eBay that was improperly listed and used the buy it now function to get it for only $120 - pretty fucking stoked on that, seller had an NOS rocker box for $30... may still buy that too, just to have this stuff around in case I grenade anything or decide to do more oil mods up top
'75 Honda CB360 - thread
« Reply #232 on: May 10, 2018, 21:30:32 »
Can someone weigh their cb360 rear brake actuator?
I made this one from aluminum and carbon fiber and it weights 1.1 ounces
Offline crazypj
« Reply #233 on: May 10, 2018, 21:34:38 »
That's really lightweight
I'll try and find onetomorrow if no one else comes through sooner
Brian Morgan, 1982
« Reply #234 on: May 11, 2018, 00:10:32 »
I had heard the GS850 pistons were lighter than stock, I had to check for myself.
Stock Honda 65mm ART
Suzuki GS850 ART
the piston pin itself probably makes the most difference since it's the heaviest part, and the Honda version is longer than the suzi one
« Last Edit: May 11, 2018, 00:12:39 by MiniatureNinja »
Offline irk miller
« Reply #235 on: May 11, 2018, 00:15:58 »
I imagine the rings weigh something too.  Looks to me like to GS doesn't have rings.
« Reply #236 on: May 11, 2018, 00:44:40 »
ohhhh -I'll have to weigh those too then, I doubt they weigh anything close to 37 grams but.. I'll see
Offline crazypj
« Reply #237 on: May 11, 2018, 10:56:30 »
It's still lighter check my sig  ;)
Brian Morgan, 1982
Offline irk miller
« Reply #238 on: May 11, 2018, 11:00:31 »
I wasn't questioning that it's lighter.  Just making an observation that things weren't weighed under the same conditions between both pistons.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #239 on: May 11, 2018, 11:05:28 »
I went with Arias on my build. 210g each. ;D
But then I broke them and swapped over to GS850s..   :(
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
