Author Topic: Cb360 Reassembly Help  (Read 18453 times)
Offline cb360j
Re: Cb360 Reassembly Help
« Reply #170 on: Dec 05, 2018, 20:50:20 »
Current problem found when trying to set ignition timing:
 I’m not getting power to the coils. I checked with multimeter from black and white wire. I checked at the blue and black wires coming from the coils themselves.
Possible issues?
« Last Edit: Dec 05, 2018, 21:02:57 by cb360j »
Offline Sonreir
  • Moderator
  • Oregon
« Reply #171 on: Dec 05, 2018, 21:19:25 »
Black/white wire gets power from the kill switch on the right control switch. Check to make sure your switch is set to the run position and also that the black wire on the control is plugged into a black wire in the harness.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline cb360j
« Reply #172 on: Dec 05, 2018, 21:24:15 »
Haha it’s funny cause I just thought that. The button was switched to the “on” position, so I switched it to the “off” position and now I’m getting power there. Did I wire something backwards?
Offline Sonreir
  • Moderator
  • Oregon
« Reply #173 on: Dec 05, 2018, 21:25:42 »
Possible?
Are you using stock kill switch or an aftermarket one?
Offline cb360j
« Reply #174 on: Dec 05, 2018, 21:28:25 »
Using the one you sold me
Offline Sonreir
  • Moderator
  • Oregon
« Reply #175 on: Dec 05, 2018, 21:30:14 »
Dammit. I think I may have sent you one of our CDI ones. You want me to sent the other style?
Offline cb360j
« Reply #176 on: Dec 05, 2018, 21:33:41 »
How do I verify if it’s one of the cdi styles? Before we do that might as well make sure
Offline Sonreir
  • Moderator
  • Oregon
« Reply #177 on: Dec 05, 2018, 22:11:34 »
If the bike runs in the OFF position, but not in the ON position.
Functionally it will work, but the switch will be backwards.
Offline cb360j
« Reply #178 on: Dec 05, 2018, 22:14:37 »
Are there any physical differences? In how the controls look
« Last Edit: Dec 05, 2018, 22:18:27 by cb360j »
Offline Sonreir
  • Moderator
  • Oregon
« Reply #179 on: Dec 05, 2018, 22:42:54 »
Minor. I'll grab a pic and send it over in a bit.
