Author Topic: Cb360 Reassembly Help  (Read 23993 times)
Offline crazypj
Re: Cb360 Reassembly Help
« Reply #210 on: Dec 22, 2018, 16:28:55 »
maybe, nope
Best thing I ever overheard
Brian Morgan, 1982
Offline cb360j
« Reply #211 on: Dec 26, 2018, 23:11:43 »
So I have the mechanism put together correctly.
But every time I put the cases back together, which has been twice now. I can’t  turn the kickstart over by hand. On my cb550 I can. So it doesn’t seem right to me. It feels like it locks up. But if I put a ratchet on the crank then I can turn the entire engine over no problem. Maybe a gear just isn’t meshing when it comes together? Is this normal ?
Offline cb360j
« Reply #212 on: Dec 27, 2018, 00:58:57 »
Maybe the bike is in gear... ? Would that make sense
Offline crazypj
« Reply #213 on: Dec 27, 2018, 23:18:02 »
The way the kick-start mechanism works is designed tio turn transmission. It should still turn over but will turn output sprocke if in geart. Have you removed spark plugs? I don't think it's possible to turn it over by hand with motor on bench with plugs in. If you have clutch plates removed you should see centre hub turn without any problem though
« Last Edit: Dec 27, 2018, 23:21:18 by crazypj »
Brian Morgan, 1982
Offline cb360j
« Reply #214 on: Dec 28, 2018, 11:39:58 »
I haven't actually looked at it yet. But do I need to remove the generator rotor before I can take the starter off, or can it come out without take that apart?
I try to study up on the manual pretty well before heading home from work but it isn't to clear on this.
Also, there is a wire coming from where the neutral switch is connected. As I don't have a neutral indicator, is this wire necessary? Can I just remove it
« Last Edit: Dec 28, 2018, 11:43:57 by cb360j »
Offline crazypj
« Reply #215 on: Dec 28, 2018, 15:13:54 »
You can leave rotor in place but you will have starter reduction and one way clutch still in place. You have to remove cover so you can get small sprocket and chain out. It's better if you remove rotor and then 3 #3 scres to remove starter clutch.  http://www.dotheton.com/forum/index.php?topic=11736.0 look at reply #10 for pic of all the parts that get removed. With a smaller battery you have a substantial weight saving (around 13lbs)
Brian Morgan, 1982
Offline cb360j
« Reply #216 on: Dec 28, 2018, 15:27:00 »
Well im not trying to eliminate the starter, just removing it for rebuild since I concluded the starter wasn't working. But thank you, that answered the question.
Offline crazypj
« Reply #217 on: Dec 29, 2018, 15:46:09 »
You still need to remove cover so you can get small sprocket back onto starter splines
Brian Morgan, 1982
Offline cb360j
« Reply #218 on: Jan 03, 2019, 11:29:04 »
Does anyone know what type of screw/thread/length connects the starter to the engine case? The two screws that go in the two left holes in this photo. Not the two really long ones.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #219 on: Jan 03, 2019, 12:09:41 »
M6 x 25, not sure about the pitch, but probably 1.25?
When in doubt, check the parts fiche.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
