Author Topic: Ducati 500 GTL 1975 Resto  (Read 5113 times)
Offline stroker crazy
  • crazy as a fox
Re: Ducati 500 GTL 1975 Resto
« Reply #40 on: Mar 11, 2019, 20:24:10 »
Good luck with the crank and rods!
Crazy
“Ride like the Wind” W.H.
Offline HansS
« Reply #41 on: Mar 12, 2019, 19:54:45 »
Well this sucks.
Looked a bit closer on the camshaft. 😤😱😵
I need a new one. It's completely worn down due to lack of lubrication.👎
And one piston is kaput.
Rings are broken and ring land is broken.👎😵
Guess am taking a break from this one and try to see if it's possible to get some more parts.
Good thing I have two other bikes that needs fixing.
Note to myself:
STOP BUYING CRAP THAT DOESN'T WORK.
Let's see if I can.😁
Offline pidjones
« Reply #42 on: Mar 12, 2019, 20:17:38 »
Don't you wish you could go back through time, locate the PO that does stuff like that, and filter the gene pool?
Offline HansS
« Reply #43 on: Mar 12, 2019, 20:31:05 »
YES.
I think I need an other hobby.
Maybe collecting stamps. But I bet that has other problems. Poisonous glue or you open a window and the wind reorganize them all.
Well I'm not worried about the engine. I will solve it.
It will take some time, but it will be running again. Maybe not this year. But I will have it running.
Offline Jimbonaut
    • Lost Apostle
« Reply #44 on: Mar 12, 2019, 23:04:23 »
Right.  The F#ck.  On.
Offline HansS
« Reply #45 on: May 14, 2019, 05:08:46 »
   Hi. Not long ago I mentioned that I was  restoring the wheels. Finaly yesterday I picked them up.
Cross-center in Habo Sweden is one of not to many companys in the world that makes spokes. Torbjörn who owns the company has made the machine that makes the spokes.
It's not cheap 3000sek a wheel not including the rims.
He laced the wheels for me. Less than 0.1mm runout.
As always I overcomplicated things and ended up with order 2 extra front rims because Borrani coulden't deliver a rim that was drilled for the correct front hub. So last rim I ordered was undrilled and I did it myself.
Some pictures.
  • crazy as a fox
« Reply #46 on: May 14, 2019, 08:51:27 »
Wheels look great!
Hope you can solve your camshaft problems soon.
Crazy
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #47 on: May 14, 2019, 09:11:14 »
Very nice! I would love to see that machine making the spokes in action.
Offline HansS
« Reply #48 on: Jun 05, 2019, 04:53:04 »
Started cleaning engine parts. Engine case turned out really nice. Needs new bearings and gaskets. Head needs some welding. Camshaft is still headache. But all in all looks good.
Offline doc_rot
« Reply #49 on: Jun 05, 2019, 12:09:05 »
you can get the cam hard-welded and reground. Not cheap but an option if you cant find a replacement....
