Author Topic: KZ750 twin high lift spring kit  (Read 287 times)
Offline doc_rot
« on: Jan 23, 2019, 16:37:46 »
I'm trying to gauge interest here and see if anybody would be interested in a group buy. The stock KZ750 springs achieve coil bind at .450" lift so the max lift that would be safe is about .400". I sent a KZ750 twin head to Kibblewhite Precision Machining and they have scoped the head and have put together a higher lift spring kit using off the shelf parts, however it does require custom retainers and base washers. This kit would allow lift up to .475"
A complete spring kit would be about $160 to-$250  depending on interest.
 in case you own a 750 twin and had not considered a cam Web  Cams will do a custom regrind  for about $350
Please let me know if you are interested, and if this is in the wrong section mods please feel free to move.
« Last Edit: Jan 23, 2019, 17:51:43 by doc_rot »
Offline canyoncarver
  • 'hacking is learning'
Re: KZ750 twin high lift spring kit
« Reply #1 on: Jan 23, 2019, 17:13:54 »
I'm trying to gauge interest here and see if anybody would be interested in a group buy. The stock KZ750 springs achieve coil bind at .450" lift so the max lift that would be safe is about .390". I sent a KZ750 twin head to Kibblewhite Precision Machining and they have scoped the head and have put together a higher lift spring kit using off the shelf parts, however it does require custom retainers and base washers. This kit would allow lift up to .475"
I might be.  What cam grind are you looking at?
Offline doc_rot
« Reply #2 on: Jan 23, 2019, 17:52:50 »
Iím talking to web cams about a custom grind. .420 in .440 ex 238 duration
