Author Topic: What carbs are these  (Read 279 times)
Offline doc_rot
« on: Feb 03, 2019, 23:35:06 »
Iím working on a CL360 for a guy trying to get it on the road. It came with these Mikuni carbs. Iím not sure what they are. Can anybody point me to info on tuning these carbs? Also any advice on a 2>1  throttle cable would be great. This one is too long and is binding.
« Last Edit: Feb 04, 2019, 03:17:27 by doc_rot »
Offline teazer
Re: What carbs are these
« Reply #1 on: Feb 04, 2019, 00:51:14 »
They are Mikuni, probably 34mm and probably from a TD3 - IF they are 34mm.
On the front of the choke plunger housing there should be two lines of numbers/letters. If you can read them, that will tell us what the bodies are from.
If they are as big as 34 they are way too big for a street bike.  It might be useful to strip and clean then anyway and to ascertain what jets and needles are fitted.  On of teh shops that sells big bore Mikuni kits for RD350/400 Yamahas (Economycycle.com for example) or as aftermarket for Hondas etc such as DCC or SUDCO should be able to supply a suitable cable.  You may have to shorten it.
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #2 on: Feb 04, 2019, 02:12:17 »
As these are rather prominent, there's a ready-made 2in1 throttle cable from a few sources. I suppose Dimecity-cycles and other such vendors should have them in stock, maybe even Nichecycle. (I am absolutely sure I saw it in the webshop of one of those two...)
My Blog:
Offline irk miller
« Reply #3 on: Feb 04, 2019, 08:18:48 »
Definitely VM.  For a 360, they should be 28mm.  Anything bigger is too big.  Places like DCC will sell 32mm as a kit for them, but 32mm is too big.  I even run the 28's on a 378 bore.  I've had decent luck with 30's, but even 30 is too big, imo.  Should have a 2.5 slide, iirc. Pull those elbows and replace with the short straight adjusters on the cap of the carb.  I run those same 2-into-1 on the Mikuni setups for my 360s but not with those elbows.  It should shorten them to a better length.
Offline cxman
« Reply #4 on: Feb 04, 2019, 08:23:31 »
if you cant find a cable pm me i have them
1978 CX650 Super Deluxe
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1974 kawasaki 350 bighorn
1983 GL1100 aspy full dress
1983 GL1100 Nekid
and a bunch of others
Offline doc_rot
« Reply #5 on: Feb 04, 2019, 17:05:41 »
thanks guys, I have ordered a cut to length cable. Haven't had a chance to dig into them yet to see what size they are. How do you sync these carbs? there is no vacuum port on the carb or boot.
Offline cxman
« Reply #6 on: Feb 04, 2019, 17:44:29 »
you have to have some slack at the cable on top and you need to make sure both slides lift at exactly the same time
look u edelbrock unisyn gauge that will work
if you have dual exhaust set the idle so both exhaust streams push the same
once you have slide lift adjusted you can get it real close with a non contact infa red thermometer get the exhaust within 20 degrees or better you are synced
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1983 GL1100 Nekid
