Author Topic: Float height CB350  (Read 206 times)
Offline Scratcher09
Float height CB350
« on: Feb 09, 2019, 00:45:18 »
I always set float height for CL/CB 350 with round floats at 22mm.  I did find info stating that it is 19, 21, or 26 depending on engine number.
#1000001-1045164......19mm
#1045165-1065378......21mm
#1065379 and later.......26mm
What is "engine number"?  VIN numbers?  My VINs don't match any of these.  I have a '71 CB and '72 and '73 CL.  Also, the set I'm currently rebuilding had 105 secondary main jets, but kit came with 115.  Should I reuse the 105s.  Will that affect how it runs (stock set up except for electronic ignition).
Offline Scratcher09
Re: Float height CB350
« Reply #1 on: Feb 17, 2019, 20:26:22 »
Anyone?  Still trying to find out correct float height.  And does anyone know where the "engine number" is?
Offline bracketmaker
« Reply #2 on: Feb 18, 2019, 16:06:51 »
the engine number is stamped to the engine. I'm a 2 stroke guy so I never bothered. do an ebay search 'blaster carburetor' and 'pz30' carburetor. I did not see your intake manifold so I put both types.
my understanding of this measurement is that it is a bullshit number and all you have to do is look to see if the metal float arm attached to the float is parallel to the bowl.
« Last Edit: Feb 19, 2019, 15:02:42 by bracketmaker »
