Re: CB360- No Evil
Got shock apart, had to make a few special tools and will need to order a couple of things to put them back together.
Had a hell of a time getting bladder out, managed to break Schrader valve off reservoir top (knew I should have removed it before I started)
Luckily, the bit fitted into reservoir is 8 x 0.75mm thread so I can modify a standard 'bolt in' tyre valve. (after I get the Loctited bit out :
Schrader is a real weird size, 7.7mm x 0.394mm pitch, only found one tap online, 70 POUNDS (about $110.00) so I ain't getting one of them
Quite surprised, they are not so badly made as I had expected, just not assembled too well.
They do have a shim stack and are probably a knock off of something more expensive
No pics yet, maybe in morning.
Swagger, thanks for pressure info, it will make a good starting point, any thought on suspension fluid?
I was thinking 7.5~10 wt with 75~100psi or 5wt with 50psi?
Rocan, looking at pics won't make you an instant expert on suspension (just letting you know before you start telling people how to fix shocks and set up suspension
