Author Topic: CB360's-from build to blog - 2013, MDS (Mo Dumb Shit)  (Read 336508 times)
Offline Swagger
  • Putting boot to ass since 1967!
Re: Yet another CB360 ( or two?)
« Reply #40 on: Dec 03, 2009, 12:11:43 »
the mounting locations don't look slotted for adjustment, is it designed in and static?
.....there's no way that little rice cooker is going 100m/h when the work need to get up to those speeds includes a big fuck off fairing shaped like a giant cock. ~Staffy
Weiner tetanus is nothing to scoff at. ~JustinLonghorn
Offline crazypj
« Reply #41 on: Dec 03, 2009, 19:59:07 »
Its a stock sprocket with the dampers removed  ;D
Probably going to put it in mill and slot holes.
 Cam timing will need adjustment because head is skimmed 0.030" which retards timing
PJ
Best thing I ever overheard
Brian Morgan, 1982
Offline Kanticoy
  • Mad Science!
« Reply #42 on: Dec 10, 2009, 22:03:31 »
 I'm thinking of building a drum front wheel off CB350/CJ360/CM400 instead of the stock disc brake.
More in keeping with 'period', home-built cafe?
I did the same thing.  I wanted to completely strip the handlebars of all of the crap...master cylinder included, and this accomplished just that!
The stock disk suck big ones anyway....IMO the drum works better.
I get not knowing, but I can't for the life of me understand not trying. It's only metal it can be fixed. Man up and risk a mistake in exchange for a lesson.
Offline crazypj
« Reply #43 on: Dec 11, 2009, 16:38:12 »
Personally,
I've had more problems with drum than disc, (usually bad adjustment by owners)
Drums fade pretty bad when your 'on the gas' ( but, I managed to burn ceenters out of dual disc CB550 brake pads as well  ::))
 I did work for Honda when the swinging arm brake was current so I know exactly how it works.
The only one that really sucks is the cable operated disc on 125~200.
 One reply is all it takes,  ;D
 Sucks I bought new spokes for disc wheel, but, I think drum will look better so thats what its getting.
PJ
Brian Morgan, 1982
Offline diesel450
  • "Fast with a past"
« Reply #44 on: Dec 11, 2009, 17:56:07 »
PJ,
I've got a 200 I'm about to start building that has that cable operated disc on it. How bad is it? I have a spare caliper off a 350 should I just plan to use that? can I use the same disc?
Offline diesel450
« Reply #45 on: Dec 11, 2009, 19:06:16 »
Deglazing just a matter of sanding clean?
I was planning on drilling the rotor anyway.
Offline crazypj
« Reply #46 on: Dec 14, 2009, 18:54:11 »
It gets better  ;D
 I got some Chrome levers off eBay because I was thinking about going with drum brake.
They turned up this afternoon as well  8)
Not the best quality in the world but they do have the built in brake switch and they were cheap ;) (and they are shiny  ;D)
 I also made some screens for brake drum holes, they are shaped to fit 'flush' with outside edge, going to makee a push piece and 'glue' them in with DEVCON as it has higher temperature rating than most epoxies, should look better than a big step you get with internal mounted ones ?
Brian Morgan, 1982
Offline Deviant1
« Reply #47 on: Dec 14, 2009, 19:00:12 »
That is nice sir! Gonna look killer.
'That's the VJMC. They don't like us... because we cut shit up." -Tim @ Barber 2010
Offline Big Rich
  • Heaven is so far away.
« Reply #48 on: Dec 14, 2009, 19:05:52 »
Glad to hear about that title PJ! What a relief, huh?
Offline Swagger
« Reply #49 on: Dec 14, 2009, 19:15:42 »
What are your thoughts on relining shoes for these old drums? I've used some pretty vicious stuff meant for forklifts and such. Works great but does seem to beat up the drum lining a bit.
