Author Topic: CB360's-from build to blog - 2013, MDS (Mo Dumb Shit)  (Read 353465 times)
Offline Swagger
  • Putting boot to ass since 1967!
Works great, I've done a few of them. Sometimes there's need to shim the depth of the bulb to get a nice pattern but I only had to do it once. I did all of mine in glass lights, it should be pretty similar in that metal can.
.....there's no way that little rice cooker is going 100m/h when the work need to get up to those speeds includes a big fuck off fairing shaped like a giant cock. ~Staffy
Weiner tetanus is nothing to scoff at. ~JustinLonghorn
Offline crazypj
Hi Folks,
I posted this in CB360 carb mods but I'm putting it here for people I've modified carbs for
Took my 360 out a couple of weeks ago and had a slight issue with lean running top end.
Didn't give it a lot of thought (although it was probably simmering somewhere in subconcious? ;) )
Came up with a theory this morning - E10 fuel
I set bike up a few years ago when E10 wasn't as common.
I had a modified set of carbs on it during week and it was a dramatic improvement.
I thought it may be just the carbs were cleaner than my own carbs, but, when I checked jets, either  someone had drilled them out slightly or they had been cleaned with jet reamers and were oversize?
Anyway, pilot was about 40 instead of 35, primary main 70 instead of 68, secondary was 115 instead of 110.
Jetting is slightly rich but if you have E-15 it should be real close to right
I wouldn't recommend E-85, it was really designed for fuel injected motors with a bunch of electronic sensors
Best thing I ever overheard
Brian Morgan, 1982
Offline crazypj
Cleaned and modified another caliper mount, going to swap out some cleaner forks tomorrow
I fitted new fork seals and oil a while ago, wasn't fitting them until I go some gaitors though
« Last Edit: Jan 06, 2013, 21:25:46 by crazypj »
Brian Morgan, 1982
Offline crazypj
Forks are swapped, brake arm with grease nipple fitted, headlight on, working good so far.
Still need to fit heavy duty clutch springs
Brian Morgan, 1982
Offline JRK5892
    • The Powder Pro
awesome!
Joe
"your life is an occasion, Stand up to it"
www.thepowderpro.com
recent builds: Hd street bob, TX cafe, KZ bratt, Goldwing tour, bratt wing, st fighter, road king, vriago bobber, chop, FXD, 1200 sporty, 1200xl sporty, GSXR, Royal enfield.. and more
Offline Mydlyfkryzis
  • 当有疑问时踢你的敌人在生殖器上,你可以道歉后
    • CB360 Build
I used a pair of Truck Shocks Gaitors...on my Nighthawk 750...Great minds think alike?
There are 10 kinds of people, those who know binary and those who don't
Ignorance is bliss....and there are a lot of happy people out there!
AlphaDogChoppers: "A friend of mine once said, "There's no such thing as a stupid question, but there sure are a lot of inquisitive idiots."
"if you need a hammer to do something...  you are probably doing it wrong" - LazloH
DTT Blue CB360 Club - We discriminate!
Mydlyfkryzis = Mid Life Crisis
1991 Honda Nighthawk 750
1976 Honda CB360t
http://www.dotheton.com/forum/index.php?topic=41649.new#new
Offline crazypj
Yep, got them from Summit  ;)
Brian Morgan, 1982
Offline crazypj
Yesterday we pulled starter motor, starter clutch and chain off Brendon's 360 so decided to weigh the bits today (while wife is working  ;) )
Fitting a 9A/hr sealed battery means a total weight saving of approx 12lbs, (over 5lbs on battery swap)
 Starter solenoid is 0.528lbs, stock battery box, 2.172lbs (including regulator/rectifier so actual weight reduction will be less)
That's about 15lbs on electrical system alone, removing starter cable and a few odds and ends is another ~1/2lb?
Stock air box with filter, 2.5lbs, that's another 5lbs dropped (haven't weighed K&N filter, I know stater block off is about 1.5 oz or less)
I'll be weighing other parts as they get taken off bike
Brian Morgan, 1982
Offline bdn3d
  • 1974 Honda CB 360T
    • Cafe-moto
Did I tell you that the 360 wanted me to tell you it's New Years reaolution was to go on a diet!  Haha!  ;D
Good things may come to those who wait, but only what's left by those who hustle...
-George Washington
http://www.meetup.com/Cafe-moto/
Offline bdn3d
    • Cafe-moto
Resolution
-George Washington
