Author Topic: CB360's-from build to blog - 2013, MDS (Mo Dumb Shit)  (Read 333776 times)
Offline trek97
Re: CB360's-from build to blog - 2013, MDS (Mo Dumb Shit)
« Reply #700 on: Mar 03, 2013, 16:45:09 »
Freakin awesome !
Offline neevo
    • The blog of my custom CB400F build
« Reply #701 on: Mar 03, 2013, 18:29:05 »
That frame is sparkling, looks mega neat. What's the finish? Paint?
See the condensed version of my full build on my blog!
Offline crazypj
« Reply #702 on: Mar 03, 2013, 18:35:13 »
Appliance epoxy over not hardened primer, gives slightly more satin finish (accidental, I'm a lousy painter  ;D )
Best thing I ever overheard
Brian Morgan, 1982
Offline neevo
« Reply #703 on: Mar 03, 2013, 22:12:42 »
Looks brilliant either way. Do you finish the tubes with anything? Reason I askis I've got some ripples from the grinder with my bike. Wondering if they won't be noticeable, a filler primer is to be used or if I need something more drastic like body filler.
Offline SONIC.
« Reply #704 on: Mar 03, 2013, 22:27:22 »
Either take an orbital sander with some 220 to it or body filler if its bad. You'll see the grinder marks otherwise
Offline crazypj
« Reply #705 on: Mar 03, 2013, 23:00:28 »
I sandblasted, etch primer, undercoat primer then 3~4 topcoats (did them on different days)
Brian Morgan, 1982
Offline MGD
    • 1989 Honda Hawk Build
« Reply #706 on: Mar 04, 2013, 00:18:50 »
Do you finish the tubes with anything? Reason I ask is I've got some ripples from the grinder with my bike. Wondering if they won't be noticeable, a filler primer is to be used or if I need something more drastic like body filler.
I had the same problem after cutting a bunch of stuff off my frame.  Sometimes body filler is too heavy for some of the small defects.  Glazing putty is the best solution I have found.  It's like concentrated primer you spread on with a rubber squeegee.  Primer/sealer you parts first, scuff them down to reveal your low spots, and fill with glazing putty.  Knock back the putty with 220, or 400 grit.  Lay one more coat of primer over it to seal it up, and then prep for paint.  Don't final paint over glazing putty, or it will show through.
Offline crazypj
« Reply #707 on: Mar 06, 2013, 01:47:49 »
It ain't easy, but, it IS possible to fit a Dyna S off a Goldwing to a CB360.
 Had to machine backplate to fit 360 head and a few other modifications. Also machined points cover for clearance, then machined it a lot more as bike won't be out in the rain
Haven't fired it up yet but we have spark at the correct time
Brian Morgan, 1982
Offline crazypj
« Reply #708 on: Mar 07, 2013, 15:47:33 »
It's alive  8)
started second kick, but, Brendon wanted video so I switched off and started over, started second kick second time as well
I'll get some pics of the Dyna fitting later
Brian Morgan, 1982
Offline crazypj
« Reply #709 on: Mar 07, 2013, 22:30:25 »
Pictures  ;D
WIP (work in progress)
Fork brace
Dyna ignition module off GL1000
modified cover as there is no longer a worry about water shorting things out
and, new footrest on 'blue bike', 2005 RM 250 take-off
Brian Morgan, 1982
