Quantcast
Author Topic: CB360's-from build to blog - 2013, MDS (Mo Dumb Shit)  (Read 356506 times)
Online ridesolo
  • You only bear responsibility for your own actions
Re: CB360's-from build to blog - 2013, MDS (Mo Dumb Shit)
« Reply #740 on: May 13, 2013, 22:51:58 »
I've postponed the surgery until next month, couldn't afford to have any issues with FMLA
 wife needed to make sure everything is in writing rather than just 'OK, your good to go'
Understand what you're saying... was in today to set up cataract surgeries and found out there is gunna' be an extra $800 out of pocket that insurance companies won't cover.  Durn medical folks, always something, huh?  PJ, good luck w/ the upcoming surgery!
“Fight on and fly on to the last drop of blood and the last drop of fuel, to the last beat of the heart.”
— Baron Manfred von Richthofen
Please check out:  http://www.VetTix.org
This is cooking away out in the shop:
'75 Honda CL378: http://www.dotheton.com/forum/index.php?topic=56547.0
This is an on-going Non-Motorcycle saga:  http://www.dotheton.com/forum/index.php?topic=71319.0
This one is FINALLY done: (!)
'70 Rupp Roadster: http://www.dotheton.com/forum/index.php?topic=67459.0
Offline jkluesner
« Reply #741 on: May 15, 2013, 15:53:44 »
Is that seat a custom job or is it a purchase? I am looking to do something similar on my 75 360T project.
Brendon called this morning, bike blowing fuses.
Forgot to take picture but the LED flasher relay had burned out (don't know why I checked that first?  :o )
bits were rattling around inside and caused a short - made it an intermittent fault
Finally got round to fitting front mudguard and finishing off fork brace. Still need to get a couple of 6mm acorn nuts (plus chop bolts down a bit)
some pix
Offline crazypj
« Reply #742 on: May 15, 2013, 16:33:29 »
It's from 'Viet' for a CB350, needed slight modification.
 He's on here, do a member search
If you give him width of frame he'll custom make one slightly wider to fit 360 frame
Best thing I ever overheard
Brian Morgan, 1982
Offline Treesus
  • Probably not sane.
    • Half Day Around
« Reply #743 on: May 19, 2013, 01:05:30 »
I had a similar issue with my old coils. Whenever I rode in rain for more than 5 minutes the right cylinder would quit firing.
I couldn't see any insulation oozing out but it was definitely shorting out somewhere when it got wet. though I could never pin down where.
I just replaced them with 3 Ohm Dyna Coils and haven't had a problem since.
~Tree
CB360 Adventure build http://www.dotheton.com/forum/index.php?topic=43834.20
"I think it says in the Bible that there is a time to listen to techno, and a time not to." -Joe Strummer
Offline crazypj
« Reply #744 on: Jun 27, 2013, 22:53:55 »
Bought a mini microscope/camera thing, was bored so I thought I'de take a look inside intake of a 360 carb
Need to play with the light adjustment (built in LED) and the focus but it looks like it's going to be possible to get stills and/or video with engine running then see the fuel discharge (no idea if lens will dissolve ?  ;D )
Probably be a few months before I can even put carbs into manifolds, real scared of doing something too soon and messing up the bits bolted into spine
Here's close up of sync adjuster screw, didn't notice the washer below lock nut
Brian Morgan, 1982
Offline OJ
« Reply #745 on: Jul 07, 2013, 13:03:35 »
What are you using for banjo bolt on the caliper? That looks much cleaner than the stock pipe.
Offline crazypj
« Reply #746 on: Jul 07, 2013, 17:48:11 »
I pull out the 90degree flare fitting and tap the caliper deeper for a normal 10x1.25 banjo bolt, I think there may be pictures somewhere in here?
 Brendon has modified exhaust system again, the outlet is now much higher and further back, about level with number plate
Says there is a very noticeable increase in mid-range power with even longer exhaust (hasn't tried top end yet)
« Last Edit: Jul 07, 2013, 17:50:51 by crazypj »
Brian Morgan, 1982
Offline OJ
« Reply #747 on: Jul 07, 2013, 22:06:59 »
Just tap and no drilling? Might try that because it makes more sense to me than the stock setup.
Offline crazypj
« Reply #748 on: Jul 07, 2013, 23:43:23 »
It's already tapped 10x1.25,just not very deep as the flare on brake line has to seat and seal
I don't remember if I had to drill as well
Brian Morgan, 1982
Offline crazypj
« Reply #749 on: Jul 08, 2013, 13:50:12 »
Brendon just sent I-Phone pic of 'new' exhaust,it's now been wrapped but don'thave pic of that yet
Brian Morgan, 1982
