Author Topic: CB360's-from build to blog - 2013, MDS (Mo Dumb Shit)  (Read 351241 times)
Offline ridesolo
  • You only bear responsibility for your own actions
Re: CB360's-from build to blog - 2013, MDS (Mo Dumb Shit)
« Reply #970 on: Apr 22, 2019, 19:24:14 »
When I finish backlog of carbs, I'm going to make a hydraulic clutch conversion. ...  I picked up a sprocket cover and realised just how easy it would be to convert sprocket cover. for hydraulic piston. I'll have to make one and see if it's feasible, only needs about 1/8"~3/16" movement
Sign me up!  If you can make that work I want to be at the front of the line to buy one.
“Fight on and fly on to the last drop of blood and the last drop of fuel, to the last beat of the heart.”
— Baron Manfred von Richthofen
Please check out:  http://www.VetTix.org
This is cooking away out in the shop:
'75 Honda CL378: http://www.dotheton.com/forum/index.php?topic=56547.0
This is an on-going Non-Motorcycle saga:  http://www.dotheton.com/forum/index.php?topic=71319.0
This one is FINALLY done: (!)
'70 Rupp Roadster: http://www.dotheton.com/forum/index.php?topic=67459.0
Offline trek97
« Reply #971 on: Apr 22, 2019, 20:18:49 »
Offline Sonreir
  • Moderator
  • Oregon
« Reply #972 on: Apr 23, 2019, 11:27:24 »
If it'll work on a CB450 I don't see why a 360 won't work.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline crazypj
« Reply #973 on: Apr 23, 2019, 23:28:55 »
I'm thinking something much 'cleaner' looking than that, inside the cover.
Best thing I ever overheard
Brian Morgan, 1982
Offline Sonreir
  • Moderator
  • Oregon
« Reply #974 on: Apr 24, 2019, 11:17:44 »
Looking forward to seeing it!
Offline crazypj
« Reply #975 on: May 25, 2019, 16:57:11 »
Just posted a quick video to You Tube, majority of carbs I get  are set toi 'over travel' so you only get about 3/4 to 7/8 actual throttle plate 'opening. I should have done the vid before I started taking carbs apart for cleaning but...............
Brian Morgan, 1982
Offline ridesolo
« Reply #976 on: May 25, 2019, 18:24:29 »
Hey PJ, I just watched this vid as well as the one you did some years ago about syncing the carbs.  Dumb question:  Are these things part of what you do when we send carbs to you?  I'm assuming they are, but I never asked...  You did mine a while back and they've been sitting in a box waiting for me to get off my posterior and get the bike done.  Am I correct in assuming that I'll still have to fiddle some w/ them once things are all together and running or should they be pretty close as-is?  Thanx, Cory
Offline crazypj
« Reply #977 on: May 25, 2019, 20:23:35 »
Yep, it'sv just one of the things I check and re-set. Should be pretty close but will probably have to adjust fuel screws as they have to match what the motor wants.  I send them out at 1-1/2 turns so I know bike will start. Sometimes secondary main jets need changing. You got to get them on the bike and find out. Carb modifying is fun but often the cleaning involved kinda slows me down (no, it always slows me down, don't like doing it  ;D )
Brian Morgan, 1982
Offline ridesolo
« Reply #978 on: May 25, 2019, 21:05:35 »
Thanx, Buddy.  I figured that, but I was a bit aggravated w/ myself for not asking in the past.  I have lots and lots of saddle time over the years, but in all honestly, not all that much wrench time, well not on bikes anyway.  The other day Levi said to me, "Before you put the engine back into the frame you are going to set the valves, aren't you?"  My answer was, "Ummmm..."  Guess I'd better look that up in the manual.
And as for the cleaning, it may not be enjoyable, but you did a beautiful job on mine, they look like new. (They look better than the rest of the engine. :(  )
« Last Edit: May 25, 2019, 21:10:04 by ridesolo »
Offline trek97
« Reply #979 on: May 26, 2019, 23:20:22 »
OMG now I have to pull and check ALL the carbs on ALL my bikes.   ;)
