Author Topic: CB360's-from build to blog - 2013, MDS (Mo Dumb Shit)  (Read 351367 times)
Offline midnightcafe
    • Flickr Page:
Re: 665----667---------Neighbour's of the Beast
« Reply #190 on: Jul 22, 2010, 12:48:32 »
nice job using the ball end mill!
Offline Rocan
  • "Long after I rest, my steel will live on"
« Reply #191 on: Jul 22, 2010, 13:00:48 »
damn PJ beautiful work! love it... cant wait to see how things go.
PJ- Cafe's don't really work right until you get rolling 70mph +
Honda CB350 Project- www.dotheton.com/forum/index.php?topic=8643.0
Honda C100 Restoration- www.dotheton.com/forum/index.php?topic=38653.0
Offline Swagger
  • Putting boot to ass since 1967!
« Reply #192 on: Jul 22, 2010, 23:56:39 »
Just make'm PJ....T-nuts are easy, especially if you can do this stuff....
.....there's no way that little rice cooker is going 100m/h when the work need to get up to those speeds includes a big fuck off fairing shaped like a giant cock. ~Staffy
Weiner tetanus is nothing to scoff at. ~JustinLonghorn
Offline Manic Mechanic
« Reply #193 on: Jul 23, 2010, 17:30:56 »
Have you dug into the Chinese dampers yet? I've got a set aswell and wanted to know if they really are gas assisted  ;D ;D
I'm guessing the piggyback is just for show.
They don't look bad from far away but up close you can tell they are a bit cheap. The spring adjusters look the worst.
Offline crazypj
« Reply #194 on: Jul 23, 2010, 19:46:01 »
 I been making them, should have 'stadardised on a thread though  ;D (well I sort of did, just wasn't smartest idea to use 10x1.25 because I have bunch of engine bolts, etc)
 Ain't got into dampers yet, been busy doing other stuff (mostly machining and polishing covers)
 Won't be puling them apart for at least another week.
I will probably make a one piece lower spring seat/mounting fork.
 Clutch cover is drilled and tapped for oil line, going to make some fittings when its back on motor
 Going to put valves back into head later and get top end buttoned up, curved 'wedges' I made should re-locate cam back in correct position but I'll degree it anyway
 I did finally finish fork brace though, put pic in machining thread
 It really is an incredibly nice piece of kit, I almost want to frame it   8)
« Last Edit: Jul 23, 2010, 20:33:24 by crazypj »
Best thing I ever overheard
Brian Morgan, 1982
Offline Rocan
« Reply #195 on: Jul 24, 2010, 02:56:21 »
awesome work pj. you should update the machining thread with pictures of your mill/tooling.  ;D
Offline crazypj
« Reply #196 on: Jul 24, 2010, 17:21:56 »
Got top end of motor finished, (except for oil line and fitting, that has to wait until clutch cover is polished)
 Thought I'd take pic of correct valve spring fitting as I've seen a few with springs on upside down over the last year or so.
 Inner and outer springs are dual rate, 'closed' coils become , in effect, a solid block which will cause valve float at high rpm if fitted upside down.
 Correct way up they act as a spacer and spring rate increases (less working coils when compressed)
Here's pic
Brian Morgan, 1982
Offline HerrDeacon
« Reply #197 on: Jul 25, 2010, 07:24:18 »
Great info PJ, I'm sure I've put a few in upside down in my years due to not knowing.
Is this the same for all bikes? Or just a Honda thing?
Perry
1972 Honda CB350 K4 / 1978 Honda XL250S /1982 Honda MB5 / 2014 Honda CB500X
Offline crazypj
« Reply #198 on: Jul 25, 2010, 10:23:43 »
 It's the same for 'everything' (cars, bikes, industrial engines)  ;D
 Fork springs are different, they have close coils UP in most cases (unsprung weight thing  ::))
 I made some good progress on clutch cover polishing yesterday, no pics as it's not shiny enough yet  ;D
Brian Morgan, 1982
Offline jay_kent
  • 1979 cb650
    • Cafe build blog
« Reply #199 on: Jul 25, 2010, 10:56:33 »
Thanks for that spring info, I'm about to put those in this week. I would have put the all springs in the same way but It'd be 50/50 if I got it right.
it's this type of detail that needs to be cataloged and put into a book, The DTT Motorcycle Re-builders Guide.
DTT build thread - here
More pics at my Cafe build blog - Here
"And yeah David...you're pretty much bugshit nuts just like the rest of us." ~Swagger
