Quantcast
Author Topic: CB360's-from build to blog - 2013, MDS (Mo Dumb Shit)  (Read 356480 times)
Offline crazypj
Re: CB360's-from build to blog - 2013, MDS (Mo Dumb Shit)
« Reply #980 on: May 27, 2019, 13:29:34 »
ridesolo- I polish various bits  for supposed performance not cosmetics, read somewhere ? years ago it helps reflect engine heat?
Trek,, Only the CV carbs although having wrong return spring can stop a slide carb opening all the way. That is incredibly rare, usually wrong cable without enough travel stops slide dropping and over-length cable is way too obvious although I have seen both done by some 'wonderful' mechanics (wonder how they never killed anyone - maybe they did?)  Even though I've worked on hundreds (maybe thousands?) of the later CB/CM 3 valve carbs I can't remember how they prevent over-travel so you'll have to post pics either in the video help or start another carb thread(or just dump them in here if it's easier)
« Last Edit: May 27, 2019, 13:33:05 by crazypj »
Best thing I ever overheard
Brian Morgan, 1982
Offline crazypj
« Reply #981 on: May 28, 2019, 15:36:41 »
\Not motorcycle related really but may interset someone?
   About 30 min ago went out to get trash cans and recycle bins from curb, it's 'DAMN HOT' about 86~89 deg F in the shade.  Checked mailbox while outside. Didn't wear shoes (I don't 'do' flip flops) and feet are BURNING. Anyway, decided to check ground temp with my HF non contact IR thermometer. Normal tarmac, 154f deg, real surprising thing,  (at least to me) the reflective strips at cross walk, 134 deg  :o I know why lawn dies off every summer, it's about same temp as the tarmac, depending on length of grass. Lowest temp on lawn was 129f
Brian Morgan, 1982
Offline irk miller
« Reply #982 on: May 28, 2019, 16:02:28 »
Yep.  This is why people are assholes that try to walk their dogs, especially on the street, when the weather is like this.  They often burn the fuck out of the pads on their dogs feet and have no clue.
Offline crazypj
« Reply #983 on: May 28, 2019, 16:36:30 »
No wonder so many dogs are pissed off all the time inFlorida (and other places that get a lot of sun) Hadn't ever thought aboutit until you said. When I used to walk step-granddaughter's dog always tried to stay on grass or go out in evenings/night. Was really surprised at grass temps, was expecting a LOT lower. HF thermometer get a bit freaked out as well when I didn't shade it, showed 1400 deg f. At least I knew that was wrong. ??? . Not so sure of temp where a truck had dropped some oil, , it was darker and showed 214f. :o
 I think I may have actually burned my feet, they are sore. I believe that only happens over 160f? Talking about feet, the sprout wa being naughty last nigh pulling on curtains and stuff. Managed to pull picture off wall which landed on his toe. (luckiliy it was one of the 3-D without glass)
 After 7+ hrs at hospital, nothing broken but bad bruise and some split skit. He slept through almost all of it  after it went numb but by 5:00am I was brain dead (no change there then  >:( )
Brian Morgan, 1982
Offline crazypj
« Reply #984 on: May 31, 2019, 13:07:39 »
Got an issue. 3 sets CB360 carbs, Jaxon has been 'very helpful' and moved carb bodies around in boxes . One set weas very dirty, missing throttle shaft plugs. One set broken idle adjuster cable, one set pretty good I know they belong to Lee, Isaac and Eric but only been in touch with Gandalf..  Jaxon thought it was hilarious when he found out apple juice washes ink off paper. I thought so too, until I realised it was return address for carbs  ::) ) Couldn't get angry with him though he's way too happy and funny.. (and wicked  ;D ) If I've got your carbs, send me a message at  crazypj10@yahoo.com That way I don't have to search the 10,000 unread I seem to have accumulated in last few weeks
Brian Morgan, 1982
Offline crazypj
« Reply #985 on: Aug 20, 2019, 02:04:18 »
Well, been a while. I finally got all the 360 carbs sorted and shipped back to the correct owners. Latest 'project ' a 'brand new ' Briggs and Stratton 125cc lawnmower engine I was given it a few months ago. As soon as I heard it run I knew big end bolts were loose.  It hadn't been used and was out of wararnty. Nothing to lose at it was free. Stripped it  Sunday, as expected big end bolts loose, one tight enough to prevent rod flying apart but 'top ' one about 1/8" backed out. Obviously never torqued properly on assembly (or there was something preventing correct tightening?) Reason I'm telling 'everyone ' I couldn't believe what other stuff was inside it A forged piston ( way more expensive than cast)and then PLASTIC gears and cam pressed or moulded onto a steel shaft ??? ?? (how cheap can you get?) Some pictures, I need to re-do piston pic as it wasn't focused
Mower really is almost brand new, kinda ' I'll take it back some time ' and just forgot  or maybe got too busy so started using a lawn service? Whatever it isn't ra real expensive one.  I also have RGHG mower here,( CB350 cafe) it too is almost new but was stored under cover outdoors for about 2 yrs as he was working 7 days a week. Still has price sticker on it though. Picture of rod and crank  as I didn't have camera handy when stripping,plus, I wanted to check threads would hold.
Cam timing is incrediby simple, arrow on black gear (at 6pm mark) lines up with mark on 'white ' gear (around 11pm)
« Last Edit: Aug 20, 2019, 02:54:03 by crazypj »
Brian Morgan, 1982
Offline SONIC.
« Reply #986 on: Aug 20, 2019, 17:03:59 »
Well that's a first.
Plastic cam. Who knew?
material science showing how far we've come I suppose.
Offline irk miller
« Reply #987 on: Aug 20, 2019, 18:53:00 »
My first full time job out of MET school after the Navy was machining pistons for Homelite.  Most of those pistons went into weed whackers. That was a real blast, let me tell you.
