Author Topic: 1977 KZ400 Build "Logan's Run"  (Read 37917 times)
Offline noahdog
Re: 1977 KZ400 Build
« Reply #20 on: Dec 10, 2009, 16:33:43 »
Yeah especially since I replaced the clubmans with dragbars which would be infinitely easier to route the wires through.
Offline diesel450
  • "Fast with a past"
« Reply #21 on: Dec 11, 2009, 23:47:57 »
Hey!!! Thats my coffee table!? and that used to be my fairing! I love it, how stuff gets passed around. Looking forward to seeing how this comes together.
As far as your seat goes; you can't get more symetrical lines that the rear end of the same tank. I like the look of that!
BTW; that fairing came to me with a 1968 Benelli 125 cobra I bought this summer. It was WAAAYYYY too big for it though.
Offline troybilt
« Reply #22 on: Dec 12, 2009, 00:53:07 »
seven degrees of seperation right?  That is too funny, I couldn't even remember where I bought it from. I think it's a sign that I've bought and traded too much stuff.
Anyhow Noah, I have some very small clear signals (brand new) that should mount right in those holes. I'm not using them. I'll be pretty busy over the weekend but I'll try to get a picture at some point.
"One should not be too distracted by definitions. Ideas transcend definitions." — Neil deGrasse Tyson
"And the days that I keep my gratitude higher than my expectations, I have really good days." — Ray Wylie Hubbard
“There are hundreds of paths up the mountain, all leading to the same place, so it doesn’t matter which path you take. The only person wasting time is the one who runs around the mountain, telling everyone that his or her path is wrong.”
— Hindu Proverb
Offline noahdog
« Reply #23 on: Dec 12, 2009, 02:30:43 »
Oh how the karma and parts flow through this forum. ;D  Hell yeah Troy I'd love to see a pic of the signals.
I can definitely see how this faring was huge on a 125 but it looks like it will fit perfectly on my 400.
Offline noahdog
« Reply #24 on: Dec 14, 2009, 16:02:55 »
Here's a link to the flush mount turn signals that I'm considering using on my fairing.   http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=280413898653&viewitem=&sspagename=STRK%3AMEWAX%3AIT
They would double as turn signals and the mounting bolt so speak to bolt the mounting bracket to the fairing.  If I used regular small bullet style lights they'd be pointing cross-eyed but the flush mount ones light up fully and are more non-directional.
My only concern is that they may look too modern for a vintage fairing and cafe bike.
What do you folks think?
Offline ridesolo
  • You only bear responsibility for your own actions
« Reply #25 on: Dec 14, 2009, 16:19:42 »
The folks here use other 'modern' things like Carbon Fiber, CNC machined aluminum bits, modern front forks, and the like, I can't really see that there's much that wouldn't work, especially if it's what YOU like on YOUR bike.  Of course, I'm not a stickler for things being 'pure and authentic.' ;)
“Fight on and fly on to the last drop of blood and the last drop of fuel, to the last beat of the heart.”
— Baron Manfred von Richthofen
Please check out:  http://www.VetTix.org
These are on a low simmer out in the shop:
'75 Honda CL360: http://www.dotheton.com/forum/index.php?topic=56547.0
'70 Rupp Roadster: http://www.dotheton.com/forum/index.php?topic=67459.0
Offline diesel450
« Reply #26 on: Dec 15, 2009, 01:15:15 »
+1 on this. It depends on what you are looking for. If you want a real vintage feel then these will probably not work. If you only want to hint at that and do your own thing then sky's the limit.
Offline noahdog
« Reply #27 on: Dec 15, 2009, 12:02:15 »
Ok how's this for an idea. The clear flush mount turn signals might not stick out like a sore thumb if I make it a theme. How about using a clear brake light and signals to tie it all together. Here's all 3 to show you the combo I'm thinking of using..
These mounted to the front fairing
And these at the rear
With this tail light tucked under the gas tank rear end seat bump.
Offline diesel450
« Reply #28 on: Dec 15, 2009, 12:06:34 »
I think that could work and would definitely improve safety. I need to see the bike done and the lights mocked up though. Get to work! ;D
Offline noahdog
« Reply #29 on: Dec 17, 2009, 00:23:38 »
Looks like the new bars will work nicely. I trimmed the fairing to fit around the gauges tonight and did a quick mock up.
Before I could even get the fairing mocked up I had to drop the front end and take the top of the triple tree apart to swap the fork ears with a pair I picked off Ebay since the original ones were pretty bent up and out of shape from a previous drop I'd guess.
« Last Edit: Dec 17, 2009, 00:26:08 by noahdog »
