Back in September I bought a nasty, ratty CB360 frame and motor off a buddy and started my first ever motorcycle build. I'll get some "before" pics up once I figure out how to bluetooth my phone to the computer. I also have more "in progress" photos I will upload.
Anyway, I am an unconventional person and this will be an unconventional build thread. First, the finished-ish product:
The gap between the seat and tank will be fixed, and the side covers will eventually come off if I get around to hiding the battery and wiring. Still with me? here we go...
First off, the seat:
The bumstop is cut from a stainless steel Ikea bowl I got at a thrift store for $2. The seat frame/seat pan is 1/8" aluminum sheet, riveted to 1/4" thick one inch aluminum angle. I figured I'll be sitting here an awful lot, so I got it professionally upholstered. The photo also shows the taillight I made from a cheap marker light. I took out the light's guts, then made a socket for a dual filament bulb using epoxy putty. I formed the putty into a block, let it mostly harden, then pushed the light into the block and pulled it back out to form the socket. When the epoxy was hard, I tapped it for screws which both hold the bulb in and make contact with the light's contacts. I glued the whole shebang into the old marker light. This way I can change the bulb if I need to.
You can also see license plate mount which is made of 1/8" aluminum sheet. The plate light is one of the lights from the gauges, with a little stainless steel reflector.
I know I've been a bit wordy so far. Plenty more to come soon. I had to make just about everything on this bike.
