Author Topic: '75 Yamaha XS500 Cafe Project - Open Throttle  (Read 95859 times)
Offline SrgtBear
  • The arsenic has oddly shaped feet...
Re: 1975 Yamaha XS500B Cafe Project (TX500) - 8/15 Electrical Stage
« Reply #80 on: Aug 16, 2010, 12:07:24 »
Here is some pictures of my gauge's back lighting issue.  There is only one power source from the main harness.  Then the power branches off to the various back lights.  All are 12volts in the wiring diagram.  I don't think changing the stem off the main source will differ since all the new back lights are LED.
Tach back light is washed out but not that bright in person.  Second picture is in pitch black.  Makes it look worse than it actually is.  It's still noticeable though.
« Last Edit: Aug 16, 2010, 15:44:27 by SrgtBear »
Ted
Kawasaki Kaiju (怪獣) - 79 KZ650 - 700cc Bore Cam Rocket - http://www.dotheton.com/forum/index.php?topic=39748.0
75 Yamaha XS500B Cafe - Completed - http://www.dotheton.com/forum/index.php?topic=14392.0
74 Honda XL 125 - Original - http://www.dotheton.com/forum/index.php?topic=25706.0
Offline Tim
  • Administrator
    • DO THE TON
« Reply #81 on: Aug 16, 2010, 12:10:09 »
Probably just different lights / translucency of the faces in the two gauges.  My gauge backlights burned out a while ago (not even running the tach light).  I don't miss them.  Hardly ever look at the gauges anyhow.
Offline JRK5892
    • The Powder Pro
« Reply #82 on: Aug 16, 2010, 12:11:52 »
mine burnt out almost right away as well, replaced them and now they are good to go
Joe
"your life is an occasion, Stand up to it"
www.thepowderpro.com
recent builds: Hd street bob, TX cafe, KZ bratt, Goldwing tour, bratt wing, st fighter, road king, vriago bobber, chop, FXD, 1200 sporty, 1200xl sporty, GSXR, Royal enfield.. and more
Offline SrgtBear
« Reply #83 on: Aug 16, 2010, 12:12:46 »
Yeah, I figured I couldn't do much.  I'll just live with them.  Not stressed about it.
Ted
Offline JRK5892
    • The Powder Pro
« Reply #84 on: Aug 16, 2010, 12:15:19 »
you can also add a resister on the power line, that would work to dim it down a bit
Joe
Offline Swagger
  • Putting boot to ass since 1967!
« Reply #85 on: Aug 16, 2010, 17:36:11 »
To work from Joe's idea, since you'd need to rewire for your resistor (a big fat one), why not convert them to LEDs? They'll draw far less current allowing your to add a couple $2 radioshack 0/5kohm potentiometers to adjust each gage's backlite to your best setting.
Just a thought....
.....there's no way that little rice cooker is going 100m/h when the work need to get up to those speeds includes a big fuck off fairing shaped like a giant cock. ~Staffy
Weiner tetanus is nothing to scoff at. ~JustinLonghorn
Offline SrgtBear
« Reply #86 on: Aug 16, 2010, 17:40:41 »
Just a thought....
I think they are already led back lights.  Plus I can't open the aftermarket gauges.
Ted
Offline Swagger
« Reply #87 on: Aug 16, 2010, 18:26:19 »
You have no access to the internal bulbs....at all? Sheesh, I guess I'll pass on them.....was looking at adding them to a quick turn bike....
Offline JRK5892
    • The Powder Pro
« Reply #88 on: Aug 16, 2010, 18:29:17 »
how can you put togther something that does not come apart
Joe
Offline Swagger
« Reply #89 on: Aug 16, 2010, 18:32:47 »
I'd imagine there's a way, but perhaps not simply. It may be like CB gauges where you have to cut the outer trim ring to access the innards.
