Will post the pics tomorrow.
Thank you very much for the help, Tintin. Since its easily available there, could you please check what its called and what size would I need?! Based on that my search will become much easier. If I do not get them here, then I could consider getting them from you.I tried googling a bit, and found this name "Pinch bolt and nut". Don't really know if its the right name.
Yes, finally I found out what its called!!! Its called a "Gear Lever Cam". Found some that fit the Enfield. So will have cut and weld it to the Honda rearsets to use them! Will take some time though for rearsets.And for the brake too, I found a brake lever from another "down-to-earth" motorcycle. Will have to try it on.
lol makes sence funny none us thaught of it since it conects to the gear level shifter and the shaft coming out of engine that its sitting on is a cam shaft
Unfortunately the rearsets are going to be delayed. Probably until we finish the next modification on the list, i.e.,The Cowl!Have taken an estimate from the fabricator, but he's charging a bomb for it. So we've decided to make the stuff on our own. Lets see how things turn out. Would look something like the below photoshopped pic. The new name will be stuck on either sides of this cowl. The cowl is going to be a removable/detachable one. Not sure how it'll be done, but we're gonna do it. The cowl work would be starting today hopefully. Will post pics as we progress. Suggestions are welcome, specially on mounting/removing/locking the cowl:
