DO THE TON
Slipstream Cycle
www.caferacerxxx.com
www.roccitycafe.com
www.oldschoolspeed.com
www.moto-madness.com
www.rustrev.com
Vintage Customs
www.monstercraftsman.com
www.bullitcustomcycles.com
DWMS Racing
Author Topic: 1975 400f Cafe Project  (Read 4368 times)
Offline MitchellSK
  • Site Supporter
    • Motion Photos
« on: May 20, 2010, 00:06:28 »
Here's how I got the bike (dig that seat man!) for $300 running & driving with title:
After a little work removing fat stuff:
Muffler removed from header and probably more changes:
Made some turn signal brackets tonight (which prompted this thread), added cafe bars, painted most everything black except the tank, swapped out the painted spoke wheels for some 350f wheels, bent up an aluminum seat blank to be trimmed and upholstered somehow, more pics coming:
« Last Edit: Jun 28, 2011, 13:57:36 by mitchellsk »
Offline Hoosier Daddy
    • My build Pics gallery
Re: 1975 400f Cafe Project
« Reply #1 on: May 20, 2010, 07:07:33 »
She's come a long way already, nice little build.
Glad you changed out those wheels, it may have looked cool once upon a time but now.... yeesh
I see a little of a rear fender, did you cut the front half off? Don't suppose there waere already holes in it for the new mount location was there? you have any more detail on that?
Don't wait for opportunity to knock... kick the door down and drag the old harlot in!
ROCK-IT '81 CB750C
STAY CLEAN '67 BSA Spitfire
BOMBER '81 GL1100
OVERKILL '80 GS750
NO CLASS '72 CB450 K5
Offline MitchellSK
  • Site Supporter
    • Motion Photos
« Reply #2 on: Oct 31, 2010, 22:46:14 »
I had a dented 750 front fender and cut it short, then spread it out, drilled holes, and bolted it on.
« Last Edit: Dec 16, 2010, 15:08:05 by mitchellsk »
Offline MitchellSK
  • Site Supporter
    • Motion Photos
« Reply #3 on: Nov 03, 2010, 00:48:01 »
Sorry for the blurry phone pics, the real camera is dead right now. Two more pics taken 11/2/2010 the bike and then the seatpan now trimmed:
(will get better daytime pics soon)
Offline bikeboy
    • a cb900 tragic
« Reply #4 on: Nov 03, 2010, 06:44:49 »
I'd ride it. Now that you've tidied it up a bit  ;D
I'll be watching what you do because I have one of these that needs attention.
cheers
ian
Offline BigBSBusa
« Reply #5 on: Nov 03, 2010, 15:44:53 »
Lookin' good.
BigBS
2003 Suzuki Hayabusa (Black/Grey)
2003 Suzuki Hayabusa (Black)
1977 Yamaha XS750 - Project Maggie Mae
1994 Kawasaki Ninja ZX11 - Project Raven
1999 Suzuki TL1000R - Project Sable
Offline MitchellSK
  • Site Supporter
    • Motion Photos
« Reply #6 on: Nov 17, 2010, 20:15:52 »
Got the turn signals working! FINALLY! Front are bulb and rear are led, both are chrome bullet. The 400f is designed to run with running lights so it has a three wire flasher. My front bulbs signals ground directly to the body but the rear LEDs have positive & ground wires. What I had to do was plug in the front orange/cyan wires, plug in the rear orange/cyan wires AND the ground wires to the green wires, AND THEN leave the green wire off of the flasher. It was like trying to pick a lock but now it works!
Also ordered new jets today so they should be in soon and I can put the carbs back on.
Also found a front brake assembly on ebay today so it should be here soon too!
All I need to do then is attach the seat pan and wire the LED rear running/brake lights and it will be roadworthy!
Then juts get the seatpan covered so it looks decent and I'll be riding... cold... but riding!
I don't know why the colors are losing so much saturation :(
Offline Slice
    • ThePersian.com
« Reply #7 on: Nov 17, 2010, 20:50:40 »
The colour could be done in a cheap candy concentrate, exposure to sun would reallllly put a damper on it over a short period of time!
-Slice
The difference between a 'bike builder' and a 'parts collector' is a fine line.
1966 Honda 305 Dream: http://www.dotheton.com/forum/index.php?topic=18950.80
1977 Honda CB550K: http://www.dotheton.com/forum/index.php?topic=26058
BLOG: www.thepersian.com
Offline MitchellSK
  • Site Supporter
    • Motion Photos
« Reply #8 on: Dec 16, 2010, 15:01:42 »
-Slice
Thanks but it's the phone photos. They look fine on the phone but between there and online are losing detail and color.
Offline MitchellSK
  • Site Supporter
    • Motion Photos
« Reply #9 on: Dec 16, 2010, 15:06:39 »
The bigger jets came in and the carbs are back on the bike. New battery, ebay caliper came in and I got it cleaned, had to clean the master cylinder again but it started up immediately and I have working front brakes again.
The chrome bullet LEDs aren't as bright as the filament chrome bullets so going to put the LEDs on front instead and I found a different stop/tail LED light I'll put on but it got too cold.
Unfortunately while sitting the tank developed a pinhole in the bottom. After wire brushing the paint off I found about five pinholes. A great old timer told me about a couple other options:
1. Put a washer on a small sheetmetal screw and screw it into the hole for a temporary fix.
2. USE AT YOUR OWN RISK: Solder the holes closed while running fumes from a small exhaust pipe (like a lawn mower) into the tank (to rid it of flammable oxygen).
I opened them up a little and tried sealing them with JB Weld but it still leaked so I ordered the motorcycle tank sealing kit from Eastwood. Directions say it needs to be 60degrees or warmer so I have to wait for the temps to rise before I can seal the tank.
It's so close to getting a tag on it!
« Last Edit: Dec 16, 2010, 15:23:22 by mitchellsk »
Offline MitchellSK
  • Site Supporter
    • Motion Photos
« Reply #10 on: Dec 29, 2010, 13:45:21 »
Ordered the Dime City universal rearsets & linkage kit this week, Herm said they're shipping today!
Offline Frankmowthelawn
« Reply #11 on: Feb 20, 2011, 11:08:29 »
Have you made any progress lately?? I'm watching to get ideas for my own 400F. I'm the original owner and want to resurrect the old girl. Thanks for the inspiration!!
FMTL
The next time you feel like complaining remember: Your garbage disposal probably eats better than thirty percent of the people in this world.
Offline MitchellSK
  • Site Supporter
    • Motion Photos
« Reply #12 on: Feb 20, 2011, 15:58:03 »
Not yet... It's been to cold to seal the tank but then I'll get tags for it, finish the seat, and make brackets to mount the rearsets... thanks for checking in.
Offline tonym547
« Reply #13 on: Mar 08, 2011, 14:03:40 »
Do you know what front ends you can switch out to get better brakes forks and handling for the 400f's
Offline MitchellSK
  • Site Supporter
    • Motion Photos
« Reply #14 on: Jun 24, 2011, 17:16:03 »
It's been a while since I've done anything BUT with July 4th coming up and my brother having his bike done already since the last time I even worked on the 400f... I got the fuel tank sealed today... FINALLY!
I used the complete Eastwood motorcycle tank sealing kit and followed the steps as closely as possible (I also did the z50 tank at the same time with the left overs since it's so small)
Now I'm rotating it every so often and have a box fan blowing air into it. I should know on Monday if the sealing kit passes or fails. I rebuilt the carbs last summer and it started great but that's when I found the tank had developed some leaking pinholes. I then ran the carb bowls dry before sitting all winter so hopefully it will be good to go with fresh gas next week and I can get take it through inspection.
« Last Edit: Jun 24, 2011, 17:18:26 by mitchellsk »
