Welcome, Guest. Please login or register.
Did you miss your activation email?
  184623 Posts in 17500 Topics by 6912 Members Latest Member: These days
Dime City Cycles
* HOME HELP LOGIN REGISTER LATEST_POSTS DO_THE_TON_SHOP CONTACT_US CHAT
Flying Squirrel Black Dice Cafe
« previous next »
Pages: 1 [2]  All Go Down Print
Author Topic: seat for KZ damned frame  (Read 419 times)
anarki650
Revered Caff Racer Idol
Offline
« Reply #10 on: Jul 25, 2010, 11:54:18 »
Deacon's tank is off either a B or C model 77-79, the tanks are the same between those models and years (other than paint that is).  I think slapping one of those tanks on your bike would help achieve the horizontal line you're looking for on the front because they drop down more over the frame spine than the LTD style tank you're running now.  They mount basically the same way, so it shouldn't be a huge pain in the ass to do the swap either.
Logged
"Being shot out of a cannon will always be better than being squeezed out of a tube.  That is why God made fast motorcycles, Bubba…"  Dr. Hunter S. Thompson.
'77 kz650 b1 cafe
'78 GL1000 bagger
DO THE TON
Flying Squirrel
 Logged
philk7
Smokin in the Boys Room
Offline
« Reply #11 on: Jul 28, 2010, 18:57:40 »
thank anarki, i'll check that
Logged
kz750 81
dcmspikes
Walkin LEGEND...
Offline
WWW
« Reply #12 on: Jul 28, 2010, 19:36:33 »
thanks for this.  ill post mine when i finish it
Logged
If you arent doing it yourself, is it really yours?
philk7
Offline
« Reply #13 on: Aug 06, 2010, 09:29:28 »
i think a found one but without petcock, do you know if my petcock of '81 can be fit on the '78 tank?
Logged
kz750 81
anarki650
Offline
« Reply #14 on: Aug 06, 2010, 22:00:19 »
Pretty sure the spacing between the mounting bolts is different between the CSR and the B/C models.  Seem to recall that the CSR tank has closer mounting holes.  There are inexpensive options for petcocks available at z1enterprises.com though...
http://www.z1enterprises.com/detail.aspx?ID=1741
Less than $40 and you're set. These are a perfect fit for the B/C model tanks.
Logged
'77 kz650 b1 cafe
'78 GL1000 bagger
DO THE TON
 Logged
Pages: 1 [2]  All Go Up Print
« previous next »
Jump to:
Browse other personalized gifts from Zazzle.
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006, Simple Machines LLC
Black22 design by Bloc
Valid XHTML 1.0! Valid CSS!
Page created in 1.386 seconds with 27 queries.
