Author Topic: Cafe seems to morph into fighter  (Read 43496 times)
Offline ctluba
Re: Cafe seems to morph into fighter
« Reply #110 on: Dec 08, 2011, 12:23:28 »
Looks good.....
  But what about "drain back" into the sump??
What do you mean??? This is a CB1100F oil pump set up. I used all the stock parts except for the cooler. As far as how the pump functions and handles oil flow, output and input etc, I let the Honda engineers worry about that.
Offline JRK5892
    • The Powder Pro
« Reply #111 on: Dec 08, 2011, 12:25:25 »
looks great man! just great!!!
Joe
"your life is an occasion, Stand up to it"
www.thepowderpro.com
recent builds: Hd street bob, TX cafe, KZ bratt, Goldwing tour, bratt wing, st fighter, road king, vriago bobber, chop, FXD, 1200 sporty, 1200xl sporty, GSXR, Royal enfield.. and more
Offline ctluba
« Reply #112 on: Dec 08, 2011, 12:26:29 »
Can you show me exactly what you did for your lines please?
Hey Rat, what exactly are you lookin for?? The lines are attached to the stock fittings on the oil pan. They run along the frame tubes, up over the triple and down to the cooler fittings. I put a few zip ties along the frame rails to keep the lines centered and away from the header. I also used the stock 1100F line guards which are like big springs that the hoses run through.
Offline Garage Rat
« Reply #113 on: Dec 08, 2011, 12:38:00 »
I mean where you put them on the pump
STFU and Ride!
http://www.dotheton.com/forum/index.php?topic=13948.0
Classic and Custom: Repair, Restoration and Fabrication!
http://www.facebook.com/#!/groups/292337884115268/
Offline ctluba
« Reply #114 on: Dec 08, 2011, 12:40:02 »
The oil lines do not attach to the pump. The dual chamber pump is located on the side of the motor near the front sprocket.
Pump on bike (actually a pic of the stock 750 single chamber pump before removal)
line fittings on front of pan
The 1100 pump has two chambers. One pumps oil through the motor, the other pumps oil through the cooler.
« Last Edit: Dec 08, 2011, 12:44:49 by ctluba »
Offline Garage Rat
« Reply #115 on: Dec 08, 2011, 12:47:09 »
OOOOoooooooo, I'll have to see if my 900C parts engine has a dual chamber.
Thanks!
STFU and Ride!
Offline ctluba
« Reply #116 on: Dec 08, 2011, 12:56:06 »
If the bike has an oil cooler, it has a dual pump. I think all the 900s had coolers stock. Well, I know the 900F had a cooler, not sure about the C.
Offline Garage Rat
« Reply #117 on: Dec 08, 2011, 13:05:50 »
My other 750K has one, but it is bolted on behind the oil filter.
STFU and Ride!
Offline Swagger
  • Putting boot to ass since 1967!
« Reply #118 on: Dec 08, 2011, 15:40:05 »
Looks pretty spiff mate but you're gonna want a 2nd mount or at least a brace at the bottom of your cooler. You're only stopping movement along one axis at this point and the bottom of that WILL oscillate back and forth until it fractures the strip mount on top.
.....there's no way that little rice cooker is going 100m/h when the work need to get up to those speeds includes a big fuck off fairing shaped like a giant cock. ~Staffy
Weiner tetanus is nothing to scoff at. ~JustinLonghorn
Offline ctluba
« Reply #119 on: Dec 09, 2011, 01:21:41 »
This is the first mock up of the mount. I can tell you one thing, the mount itself is SOLID!! After my buddy welded it I held it like a handle and picked up the front of the bike just to test its strenght, didnt budge.
If you are talking about the cooler itself flexing, I did not consider that. The thing is very rigid and compact. I dont think it will move at all. The "casing box" or "frame" of the cooler is strong. I will take a look at it again though and maybe tac in a small brace from the bottom edge just prevent any flexing, definately wouldnt hurt anything.  ;D
