Author Topic: '77 CJ360T (Café SOS) - Calling it Done (for now...)  (Read 145894 times)
Offline Sonreir
  • Moderator
  • Oregon
Hey all,
I'm two weekends into my first build and things (I hope) are going well.  Obviously, I started out with stripping down the bike to the frame and taking everything apart.  Most everything went well.  I did encounter a lot of metal dust when I removed the front sprocket cover and I'm still trying to figure out the reasons.  At this point, I'm leaning toward my poor chain maintenance (haven't lubed it in a while).
I also had a bit of trouble getting the oil plug out.  I ended up rounding off the corners and had to use a set of vice grips to finally get the damn thing out.  So now I'm in the market for a new 17mm bolt.  ;)
« Last Edit: Jun 01, 2012, 01:16:12 by Sonreir »
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline Sonreir
  • Moderator
  • Oregon
Re: '77 CJ360T Café Build
« Reply #1 on: Oct 27, 2010, 14:16:42 »
Anyway... after three hours of the first weekend I got myself to this point:
« Last Edit: May 09, 2011, 12:30:54 by Sonreir »
Offline Sonreir
  • Moderator
  • Oregon
« Reply #2 on: Oct 27, 2010, 14:21:24 »
This last weekend, I finally got the front wheel and forks off.  I also removed the swingarm and started grinding with my angle grinder.  All non-essentials have to go.
So far, I've removed the helmet hooks, center stand mounts (mostly), and two of the three battery box mounts.  Still up on the chopping block are the rear footpeg mounts, airbox mounts, and seat mounts.
From the swingarm, I've removed the chain guard guide and the zerk fitting (PO welded the damn thing shut so I just removed it).
« Last Edit: May 09, 2011, 12:32:08 by Sonreir »
Offline IndieSol
  • "This one goes to eleven." -Nigel Tufnel
    • Project: Pariah
« Reply #3 on: Oct 27, 2010, 18:50:25 »
Hey, Sonny.  Hope things are going well.
BMW R100
XT350
CJ360 Cafe Project
Project: Pariah
Offline Sonreir
  • Moderator
  • Oregon
« Reply #4 on: Nov 01, 2010, 14:11:19 »
OK.. more work done over the weekend. I've ground more stuff off of the frame. Gone now are all of the air box mounts, both seat mounts, and the rear fender guides. Still to go is the front battery box mount and possibly the entire part of the frame with the rear footpeg mounts. I'm a bit nervous about that last section though as I can't remember what (if anything) else gets attached to that part of the frame except the rear footpegs. There's some hols there but I can't remember if they're just for the exhaust or for something actually important. Anyone have some pics of the rear right side of their 360 they can post?
Anyway... I cracked open the engine and the head is now removed. Most everything looks good, but I haven't specced any of it. The rocker arms on the left side look they're quite worn, but the ones on the right seem just fine. Oil starvation? Also, the inside of the cylinders seem OK, but I won't know for sure until I get everything fully dismantled. The valves are different colors between the two clyinders. Was one side running rich or was the other lean?
Finally, the rest of the engine teardown is on hold until I can locate a tool to remove the nut that holds the oil filter in place. I'm looking at ebay right now to get one.
Thanks,
Sonny
Offline Sonreir
  • Moderator
  • Oregon
« Reply #5 on: Nov 01, 2010, 14:12:03 »
Just more pics.
Offline IndieSol
    • Project: Pariah
« Reply #6 on: Nov 01, 2010, 18:02:50 »
Foot pegs and muffler.  Excellent progress so far.
BMW R100
XT350
CJ360 Cafe Project
Project: Pariah
Offline Sonreir
  • Moderator
  • Oregon
« Reply #7 on: Nov 01, 2010, 18:45:46 »
Indie,
Do you have a bigger pic?  If not, can you please confirm something for me?
In the attached picture, is the only thing mounted to the circled section of frame is the exhaust and the rear foot peg?
« Last Edit: Nov 01, 2010, 19:35:19 by Sonreir »
Offline IndieSol
    • Project: Pariah
« Reply #8 on: Nov 01, 2010, 18:47:12 »
That's correct.
BMW R100
XT350
CJ360 Cafe Project
Project: Pariah
Offline belch_brother
« Reply #9 on: Nov 01, 2010, 19:18:36 »
This is a cj250t but its the same setup.. indie is correct.
honda_cj_250_t_1977_4 by belch_brother, on Flickr
