Slipstream Cycle
www.caferacerxxx.com
www.roccitycafe.com
www.oldschoolspeed.com
www.moto-madness.com
www.rustrev.com
Vintage Customs
www.monstercraftsman.com
www.bullitcustomcycles.com
DWMS Racing
Author Topic: 79' CB750K Rebirth  (Read 5549 times)
Offline thirsty 1
  • In a blind world, The one eyed man is King!
Re: 79' CB750K Rebirth
« Reply #45 on: Mar 12, 2011, 21:12:11 »
I finally got some time around work to make a real tach bracket with a spot for the choke cable. Came out good, nice and clean up front now. Also made a bracket for my newer coils. I think they were off of a chevy cavelier or something.
On to the tank now... Man I really suck at the whole bondo paint thing! I guess I just dont have the right tools.. ya thats it. I dont' have the right tools..LOL
73' CL125s, 75'CB400F, 77' R100/7, 02 bmw k1200rs, sold the 79 CB750
79' DOHC build
http://www.dotheton.com/forum/index.php?topic=19923.0
Lacing Spoked Wheels: http://www.cb750c.com/modules.php?name=Forums&file=viewtopic&t=14177
Offline dewjantim
  • duc in the park.....
« Reply #46 on: Mar 13, 2011, 00:13:05 »
That is one sweet lookin' set of brackets you made. As for the tank...... sand it smooth..... then...... sand it again and again......
If it hurts....... you ain't dead yet !!!!!!
Offline hedrives
« Reply #47 on: Mar 16, 2011, 10:59:59 »
Hey, your project is looking great.
I'm also running a small headlight mounted like yours. Looks much better.
Sorry, but I need to warn you on using those GM coils.
I went with a set of those and ended up replacing them after being shown they are a bad match.
The primary resistance of the stockers is 2.8 ohms.
The primary resistance of the GM coils is 0.6 ohms.
 So, there's a chance your ignitors could fail from being overloaded by driving 0.6 ohm coils instead of 2.8 ohm coils.
Check ebay for a pair of green Dynas.
Here is a link for a pair
http://cgi.ebay.com/ebaymotors/Dyna-S-coils-3-ohm-tested-good-only-used-short-time-_W0QQcmdZViewItemQQhashZitem2eb3d452b5QQitemZ200585532085QQptZMotorcyclesQ5fPartsQ5fAccessories
Another guy has one:
http://cgi.ebay.com/ebaymotors/DYNA-COIL-3-0-OHM-ONLY-HAVE-1-NOT-PAIR-_W0QQcmdZViewItemQQhashZitem19c3d9529cQQitemZ110659981980QQptZMotorcyclesQ5fPartsQ5fAccessories
Keep up the good work.
brad in Hugetown
Offline thirsty 1
« Reply #48 on: Mar 17, 2011, 23:29:17 »
No need to be sorry Hedrives I'll take my chances.  ;D   Some have got 10K plus out of them and still riding. I cant afford 100 plus dollars for a set of coils. Hell I only paid 250 for the whole bike so I'll roll the dice. Thanks though !  I was actually thinking of put the ignitors from the chevy cavalier on it. Couldnt hurt I suppose.
dewjantim  -   been sanding and painting and bondo and sand and primer and sand and bondo and primer damn damn damn damn  sand primer repeat.....it's looking decent now !  Silver stripe down the center soon....
79' DOHC build
Offline dewjantim
« Reply #49 on: Mar 18, 2011, 00:11:02 »
I still remember my hands and fingers getting raw in shop class from all that sandin', fillin', sandin', fillin'...... The main reason I quit.
Offline hedrives
« Reply #50 on: Mar 18, 2011, 09:57:52 »
Good plan.
Using the GM ignitors is not a bad idea. There are threads out there that show how to do this.
No matter what, enjoy the build and thanks for sharing.
brad in Hugetown
Offline thirsty 1
« Reply #51 on: Mar 18, 2011, 14:17:08 »
Ya Brad thanks for the well wishes it keeps me going. I think I seen something on the DOHC Customs site about using the other ignitors. I just bid on a set of stock coils too..
79' DOHC build
Offline hedrives
« Reply #52 on: Mar 18, 2011, 14:28:11 »
If you sign up for cb1100.net forum there is a great thread about the GM ignitors here:
http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=23870&start=240
I readily admit I'm not very knowledgeable about ignition systems, but I can wire them!
No matter what, keep digging. I'm enjoying your updates.
Offline thirsty 1
« Reply #53 on: May 01, 2011, 14:33:28 »
Well I found my thread back on page 12  :o , so I guess it's time for an update. I finally got my tank painted after sanding about 10 times. There's some sort of coating on it from a previous owner and everytime I'd put some paint down it would bubble. ???   I got sick of dealing with it so to hell with it, it's good enough. I'm not trying to build a show winner anyway.
I also got all my new controls from Dime City Cycles of this site. Thanks again!!! New waffle grips, double pull throttle tube and a new clutch lever and perch. Good stuff at a good price. Gracias'
Made some new little brackets for my ignition switchs and the cockpit is now done.
Nice and simple - two switches.
Went back and bought a used set of coils off ebay $5.99 with shipping. Sweet! I came to the realization that I don't need to over load the spark boxes and have it fail in the middle of no where.
So I made up a small gas tank and cranked it till I hade oil pressure. Hooked my coil power wire VROOM VROOM . It's alive!! :D   :D   :D
Let it warm up some and took it for a spin around the block!
Now for a seat those frame rails hurt!
« Last Edit: May 01, 2011, 14:36:48 by thirsty 1 »
79' DOHC build
Offline Garage Rat
« Reply #54 on: May 01, 2011, 16:10:18 »
Where have I been? Theres a TON of DOHC CB's now!
STFU and Ride!
http://www.dotheton.com/forum/index.php?topic=13948.0
Classic and Custom: Repair, Restoration and Fabrication!
http://www.facebook.com/#!/groups/292337884115268/
Offline thirsty 1
« Reply #55 on: May 01, 2011, 17:47:05 »
I used this for wiring it up and it does work. I used toggle switches.
79' DOHC build
Offline thirsty 1
« Reply #56 on: May 01, 2011, 17:48:14 »
You have to get out of the garage I guess...
79' DOHC build
Offline Garage Rat
« Reply #57 on: May 01, 2011, 21:52:01 »
I have to get in it... Im waiting to take possetion of my house, i just went for a ride and im bored out of my mind. My stuff is jammed in three different garages around town and im living in the wifes house for the next two weeks.
Im having wrenching withdrawls...
STFU and Ride!
Offline thirsty 1
Re: 79' CB750K Rebirth {It's Alive}
« Reply #58 on: May 02, 2011, 00:05:31 »
Right on! Congrats.!!!  I gotta felling you have that project of yours spread out like a tramp on saturday night.  ;D  .  My thinking on the DOHC bikes is supply and demand. It's getting harder and harder to find cheap projects and since the DOHC bikes are not so desireable there cheap. for now.
« Last Edit: May 02, 2011, 00:34:57 by thirsty 1 »
79' DOHC build
Offline Garage Rat
« Reply #59 on: May 02, 2011, 14:53:23 »
Have you seen what the 70's CB's are going for now!?!
STFU and Ride!
