johnny gaijin
sorry i realize this has been covered before but i've read all i can find about it and i'm still having no luck.
replaced the clutch cable on my '75 cl370 recently.
the loose ball bearing is greased and in place.
following the manual i dialed both ends barrel adjusters all the way in to make the cable as slack as possible.
again following the manual i dial the adjustment screw counter-clockwise until i get resistance and then back it off 1/4 of a turn.
at this point i pull on the clutch lever and when it gets near the end of the pull POP the cable goes slack.
so i try again (and again and again) and find i can get it to not pop if i dial the adjustment screw in until i get resistance and then dial it another couple of turns past that point.
doing it this way though the clutch disengages at the very beginning of the lever pull. i only use maybe 10% of the pull.
when i replaced the cable the piece w/ the 3 ball bearings popped out and i'm not sure which direction it's supposed to go.
crazypj had this to say about it:
There are 3 ball bearings in lift mechanism and a fourth inside center hole (where pushrod fits)
The plates have a sharp edge and a rounded edge (because of the way they are made, stamped out from sheet )
Theory is,
rounded edge 'out' clutch is easier to lift but may engage more abruptly.
rounded edge 'in' clutch has smoother engagement but slightly more drag when lifting.
but i'm not sure which way 'out' is or which way it should go to solve my problem if indeed it were the solution.
i'm stumped!
thanks in advance!
Theory is,
i'm stumped!
thanks in advance!
