www.Moto-Madness.com
Author Topic: My Suzi T500 Project *New Video*  (Read 224697 times)
Online Walms
My Suzi T500 Project (New Video)
« Reply #1080 on: Feb 08, 2014, 08:30:36 »
Have you done a leak down test on the motor yet? I know with our triples, with the exhaust and intake sealed, you should be able to hold 6psi of pressure and vacuum. If you have lab seals, you'll have to do both at the same time.
« Last Edit: Feb 08, 2014, 08:33:18 by Walms »
Offline clem
  • static fluff
Re: My Suzi T500 Project (New Video)
« Reply #1081 on: Feb 08, 2014, 11:39:28 »
It seems to be hanging on to the rpm when you let off the throttle... an Air leak or too lean maybe?
+1 on this. The idle tells the story.
Offline johnu
« Reply #1082 on: Feb 08, 2014, 17:47:14 »
Ok great feedback!  It only started with the revs not going down since I put the small pilots in.  I will research "leak down test" as no, I have not done it.  What are lab seals?
Going to get a video of me riding the bike when my son comes home on leave this week :)
Offline clem
  • static fluff
« Reply #1083 on: Feb 08, 2014, 21:23:24 »
Labyrinth seal on the crank. Has nothing to do with the david bowie movie.
Offline HollywoodMX
Re: Re: My Suzi T500 Project (New Video)
« Reply #1084 on: Feb 09, 2014, 13:46:33 »
Before leak down, have you tested the intake components for leaks like I suggested earlier? It takes 2 min.
A couple ways; while running you can spray starting aerosol between the carbs and the engine and see if it Idles up. If it does you have a leak.
You can use water or break cleaner instead in which case it will idle down as the sign.
Even though it more dangerous I find the starter fluid is more sensitive in telling me there are intake leaks vs the others.
TR1 Build thread: http://www.dotheton.com/forum/index.php?topic=54733.0
Xv920 Tracker thread: http://www.dotheton.com/forum/index.php?topic=59754.15
77 KZ1075 Supercharged - 81 Yamaha XV920rh (x2) - 06 YZ250 highly modified - 08 Hyabusa
"I live my life a 1/4 beer at a time"
Offline johnu
« Reply #1085 on: Feb 10, 2014, 19:32:41 »
Did the spray test with water and there are no leaks on the intakes, not brave enough to use the starter fluid ;)  I fitted all new crank seals when I built the motor up, I know how important this is (i use to change seals after every race weekend on my race engines).  I will do the leak down test as obviously there is something wrong but I think maybe I just went too low with the pilots.
Online Walms
« Reply #1086 on: Feb 11, 2014, 07:30:41 »
Here's a short video of my bike on first start up. It's dead rich, probably too rich to ride but at least you can listen to how the rpm drops quickly.
Offline HollywoodMX
« Reply #1087 on: Feb 11, 2014, 12:12:12 »
Starting with one kick I don't think that's super rich especially if it was cold. The air circuit never made a difference with that jetting? I would be inclined to switch to those pilots and lean the needle 2 clips and go for a test drive.
Online Walms
« Reply #1088 on: Feb 11, 2014, 12:18:27 »
Yup, it was... ;) like having the choke on it was so rich.
Confirmed as soon as she went on her maiden voyage.
Offline teazer
« Reply #1089 on: Feb 11, 2014, 13:46:14 »
Walms and JohnU are both correct.  Walms bike was way rich and JohnU's bike is NOW too lean at idle with those 22.5s where it was too rich before with larger pilot jets.
So it needs slightly larger pilots but probably needs to be leaner as it comes off idle.  That suggests a larger cutaway might clean that up.  I also wonder if the pilot air jet system is clogged or maybe the air jet is too small to have any effect.  I think it's a drilling in those carbs and it's worth checking.
