www.Moto-Madness.com
Author Topic: My Suzi T500 Project *New Video*  (Read 208411 times)
Offline HollywoodMX
Re: My Suzi T500 Project (New Video)
« Reply #1090 on: Feb 12, 2014, 02:07:08 »
Shit I'm confused.  I didn't look to who I was responding to.
TR1 Build thread: http://www.dotheton.com/forum/index.php?topic=54733.0
Xv920 Tracker thread: http://www.dotheton.com/forum/index.php?topic=59754.15
77 KZ1075 Supercharged - 81 Yamaha XV920rh (x2) - 06 YZ250 highly modified - 08 Hyabusa
"I live my life a 1/4 beer at a time"
Offline johnu
« Reply #1091 on: Feb 12, 2014, 11:03:27 »
Your confused??? Join the club haha ;D
Offline johnu
« Reply #1092 on: Feb 12, 2014, 11:05:09 »
Walms and JohnU are both correct.  Walms bike was way rich and JohnU's bike is NOW too lean at idle with those 22.5s where it was too rich before with larger pilot jets.
So it needs slightly larger pilots but probably needs to be leaner as it comes off idle.  That suggests a larger cutaway might clean that up.  I also wonder if the pilot air jet system is clogged or maybe the air jet is too small to have any effect.  I think it's a drilling in those carbs and it's worth checking.
Going to take the carbs off today AGAIN!! and check them AGAIN for any blockages ;)
Offline teazer
« Reply #1093 on: Feb 12, 2014, 12:46:48 »
John,
The situation you had earlier appeared to be rich at idle or was it just off idle as you started to open it up?  I don't have a full picture of what the symptoms were at different revs/throttle settings with those different pilot jets and air screw settings.
In other words, if you can get the idle OK with say a 30 pilot jet but it bogs as the slides are lifted to say 1/4 open then it is likely to be an issue of transition from the pilot circuit to the main circuit and that's where the cutaway comes in to play.  If it's wet and soggy at say 1/4 to 1/2 it's more likely to be the needle jet.
Easy check on the air circuit would be to remove the pilot jet , loosen the screw and spray carb cleaner down teh air inlet.  If it sprays back in your eyes, you know it's blocked (and you need to see an eye specialist)  If it sprays out of teh pilot jet holes (up or down) it's probably not a problem.
Offline HollywoodMX
« Reply #1094 on: Feb 12, 2014, 18:19:52 »
I would put in the 35s or whatever you have close to. I would lean the needle 2 clips.
Start the bike. Let it warm up. Test the air screw. If no notable difference, Then with one hand hold the throttle to around 2000 rpm steadily as possible , with the other hand adjust the air screw and see if there is a difference in it idling up and down then. I would also take it for a quick boot to test the needle change.
Offline johnu
« Reply #1095 on: Apr 08, 2014, 12:59:26 »
Ok guys, thanks to all of you that voted for my bike this month!
Everything will be at a standstill for quite a while as I just unexpectedly had to have open heart surgery!!  I have had a pacemaker for the last ten years (when i was 40) because I have a very low resting heart rate (about 40 during the day but dipping in the 20's at night) well last week they removed the pacemaker as it was giving me grief but when the took the wire out it tore the wall of my heart so they had to do open heart surgery to repair it.  I am very fit ( i can out cycle most guys half my age) have no clogged arteries or bad valves so hopefully I can recover quickly :)
Probably going to be about six weeks before I can fire the bike up again :(
Offline Walms
« Reply #1096 on: Apr 08, 2014, 13:17:11 »
Wow, sorry to hear John, all the best on a quick recovery!
Offline Rich Ard
  • doin' the backstroke in an estrogen ocean
« Reply #1097 on: Apr 08, 2014, 13:48:46 »
Some guys will do anything to get out of working. Get better man.
unplug the connectors from the harness and multimeter the shit out of them
Bad Points, a comic :: CB450 Restomod (sold) :: Viragostrosity :: GL1000 daily rider :: Kaw 175
Offline Mr_Dunev
  • I have no idea what I am doing
    • VintageCycleTrader.com (currently under construction)
« Reply #1098 on: Apr 08, 2014, 13:54:20 »
I hope you recover quickly. Don't worry about the bike, it will be there when you get better. Taking care of yourself is priority numero uno.
YAMAHA: 73 TX650, 75 RD350 76 RD400, 71 CS3, 80 XS650 75 RD200, 64 YJ1, 72 DT2mx,
73 MX250, 74 MX250A, '76 HL500, 77 TT500,
78 TT500,
KAWASAKI: '69 H1, 77 KH400, 72 S3,
72, S2, 71 F6, 72 H2, 73 H2, 72 H1, 73, H1,
74 H1 (2), 70 A1, 75 KH250, 73 S2
HONDA: '73 CR250M, 70 CB350, 70 CL350
Offline clem
  • static fluff
« Reply #1099 on: Apr 08, 2014, 14:19:12 »
I hope that you get recover soon. From what I see here, you seem like a really good dude.
