www.Moto-Madness.com
Author Topic: My Suzi T500 Project *New Video*  (Read 234288 times)
Offline Maritime
Re: My Suzi T500 Project (New Video)
« Reply #1110 on: Apr 11, 2014, 13:21:02 »
And it was a BOTM too. John hope you heal up fast and well.  Cheers
Maritime
Offline johnu
« Reply #1111 on: Apr 11, 2014, 14:30:59 »
Maritime
Thanks, feeling better every day!
Offline HollywoodMX
« Reply #1112 on: Apr 12, 2014, 01:50:32 »
Thanks for all the well wishes, I am feeling better everyday :)
Now I have all this time on my hands my mind wanders and that means thinking about future projects ;)  If I could choose my next bike to build it would be one of three choices all totally different, #1 Kawasaki 650 Ninja (twin cylinder 4stroke) #2 Suzuki dr800 (single cylinder 4stroke) #3 Yamaha lc350 (twin cylinder 2stroke).  The Kawi would be my #1 choice maybe a crash damaged bike as I wouldn't be using much of the frame or suspension.... we shall see.
Ita to bad we don't get the honda Africa (better than the dr800 aka Dr big).
TR1 Build thread: http://www.dotheton.com/forum/index.php?topic=54733.0
Xv920 Tracker thread: http://www.dotheton.com/forum/index.php?topic=59754.15
77 KZ1075 Supercharged - 81 Yamaha XV920rh (x2) - 06 YZ250 highly modified - 08 Hyabusa
"I live my life a 1/4 beer at a time"
Offline cobraace2
« Reply #1113 on: Apr 12, 2014, 18:15:28 »
John I new you were gone get botm sooner or later well deserved . OH get well soon .Hey did you have any custom work done porting of the heart valve maybe boysen reed valves    ;D us old guys need all the help we can get
Offline johnu
« Reply #1114 on: Apr 15, 2014, 14:55:08 »
Haha only a slight tune up on the heart wall plus remove an old pacemaker wire, all valves and arteries are fully ported and wide open (like new) like a factory racer.  I should be hammering kids less than half my age on the mountain bike again in about 6 months.
My boy is going to start the Suzuki on Friday when he gets home on leave.  I am having him make some carb adjustments first just to see if I can make a little headway.
Offline cobraace2
« Reply #1115 on: Apr 16, 2014, 12:07:56 »
Great show those kids how its done . Thank your son for his service for me  ;)
Offline johnu
« Reply #1116 on: Apr 16, 2014, 14:03:46 »
Will do!
Offline farmer58za
« Reply #1117 on: Apr 17, 2014, 03:49:05 »
Johnu
I'm just new here. Saw you had open heart surgery. Glad to see you're recovering.
I've had some done too and it's ok, you'll be as good as new soon.
In the meantime, put your son to work on the Suzuki!
Regards
David
Offline johnu
« Reply #1118 on: Apr 18, 2014, 18:57:06 »
Johnu
Regards
David
Thanks for the encouragement!
Offline johnu
« Reply #1119 on: Dec 01, 2016, 17:54:15 »
Ok guys I finally started working on the 500 again. Unfortunately I never did get it running right so I am going to completely strip the engine again and totally rebuild it. Last time I didn't have the crank rebuilt because po said it had been done recently. I now believe that was not true.
Biggest problem I had was that it ran like it had an air leak, when you revved it up it the revs didn't die down right away.
I must confess that I short cut the original rebuild and now regret it. After Eric did the porting I was going to have the cylinders bored to next size over (max) and fit new pistons (i bought some on ebay for $60 brand new) but I just ended up putting new rings in it. Also I never skimmed the 0.020" off the heads that Eric suggested.
So the plan now; Strip engine completely and have the crank split and install new center seal. Buy new forged pistons (max oversize) and get cylinders bored.  Skim 0.020" from heads. Of course I installed new outer crank seals last time I rebuilt it but I will put new ones in anyway. I plan to use Bill Bune to do the crankshaft and boring unless there are any other suggestions here? I will do the heads myself.
I want to do this right this time so if anyone has suggestions for anything else I should consider doing while building the engine fire away :up: The bike will run on Sunnoco standard leaded race gas (no more ethanol crap for me :lol: )I am building this bike to use mostly at trackdays.
Just drained the oil out before I remove the engine and it is about 50/50 oil and gas (petrol).
