Author Topic: My Suzi T500 Project *It's Alive Video*  (Read 264657 times)
Offline BillyGoat4130
    • Live Oak FL Real Estate
Re: My Suzi T500 Project *New Video*
« Reply #1220 on: Feb 17, 2017, 16:37:57 »
That's great! This is a super cool build, I may borrow your dash and tach cluster for my Rotax project... Looks like a nice setup.
Sent from my SM-N910V using Tapatalk
The question isn't who is going to let me, it's who is going to stop me.
You can't reason with the unreasonable.
Too dumb to quit.
Insta: https://www.instagram.com/hondaatc/
Photography: http://wgolightly.smugmug.com
Real Job: http://landsofnorthflorida.com
Offline johnu
« Reply #1221 on: Feb 17, 2017, 18:58:24 »
Rotax, what Rotax????  I use to race them in Karts!
« Reply #1222 on: Feb 17, 2017, 19:04:48 »
It's a hybrid but I just refer to it as a Rotax since that's what the top half of the motor is, http://www.dotheton.com/forum/index.php?topic=72424.0
Too dumb to quit.
Offline johnu
« Reply #1223 on: Feb 17, 2017, 19:51:13 »
Jeezus Billy how did I miss this one???  I haven't had time to read through it all yet but looks like an awesome project :o
« Reply #1224 on: Feb 17, 2017, 20:50:29 »
Well thank you for the kind words! You have a beautifully built bike here yourself. Us two-stroke guys got to stick together haha
Too dumb to quit.
Offline Joon-yah
  • Joon-yah
« Reply #1225 on: Feb 21, 2017, 09:36:23 »
Glad to see you're getting her all squared away bro
Cm400/cb450 http://www.dotheton.com/forum/index.php?topic=45376.0                                                  SR500 http://www.dotheton.com/forum/index.php?topic=43591.0                                                     http://retromoto1.com/
Offline johnu
« Reply #1226 on: Feb 21, 2017, 18:36:00 »
^^^^ Thanks :)  Getting closer to the finish video 8)
Offline johnu
« Reply #1227 on: Mar 09, 2017, 18:09:19 »
Just took my carbs off to change the pilots to 40's (currently 45's).  Air screws aren't doing anything when I try to adjust them, in or out changes nothing so I'm trying the smaller pilots.  I also noticed that the slides on both carbs have different gaps at the bottom when they are both all the way down.  The right side is 4.5mm and the left is 3.9mm they are both 2.5 slides.  Not sure it matters when the idle is adjusted using the tapered screws.
Offline teazer
« Reply #1228 on: Mar 09, 2017, 19:53:35 »
That's odd.  Are they both closed at the engine side?  If not, what is causing one to hang up?
If they are closed, put the two slides facing each other and see if one has been modified to a larger cutaway.
« Last Edit: Mar 09, 2017, 21:10:01 by teazer »
Offline irk miller
« Reply #1229 on: Mar 09, 2017, 20:09:11 »
This might sound obvious, but are the slides switched between the carbs?
