Author Topic: My Suzi T500 Project *It's Alive Video*  (Read 256379 times)
Offline johnu
Re: My Suzi T500 Project *New Video*
« Reply #1300 on: Apr 12, 2018, 22:14:36 »
John, there is no way that I'd use a "Y" or "T" to dual carbs and .25" might be smallish?  On my '75 T-500 I have a dual outlet Pingle petcock to my carbs. BTW it's a bolt up to the Suzuki tank, I know you built that beautiful tank but I can't recall the bung you used?  The Pingle flows enough for a big drag bike engine, Pingle says "Don't let your Petcock be your main jet"
  Cheers, 50gary
Is this what you used?
Offline 50gary
  • Under the Limelight
« Reply #1301 on: Apr 13, 2018, 10:07:27 »
For the most part yes, mine doesn't have the plate with the two bolt holes.  Mine has a 22mm (OEM, Suzuki T-500) bung so it's a simple 'bolt up' to the Pingle petcock.  Dual outlets, ON/OFF/RES.  The body is also not styled with the grooves, mine is smooth chrome.
  Cheers, 50gary
http://www.pingehttp://www.pingelonline.com/pc_product_detail.asp?key=5FFF4EB8132F496080ECF1EC12684B42lonline.com/pc_product_detail.asp?key=5FFF4EB8132F496080ECF1EC12684B42
« Last Edit: Apr 13, 2018, 18:45:45 by 50gary »
Short track speedskating, cycling, guitars, motorcycles, juggling dynamite. I was born to laugh at Tornadoes.
Offline johnu
« Reply #1302 on: Apr 13, 2018, 13:38:42 »
You are not using the main jets on a short ride unless you are hammering it, so let's go back a step. I can't remember if you tried swapping carbs from side to side to see if the problem changed sides.  Or if you swapped coils side to side to see if that changed things, but those are cheap and easy to do.
Are the plug leads and caps new and tested?
If it is the jetting, try going down one size on the pilot jets just to test that theory and drop the needles to the top clip position and see if that makes any change.
Richard I didn't switch the carbs around so I will try that!
There is only one coil with both ht leads coming from that.  I don't think you can fit new leads as they look to be an integral part of the coil.  A new GT500 coil is expensive :o  I will keep looking around for one though. I assume I have to use an original coil.
« Last Edit: Apr 13, 2018, 13:42:22 by johnu »
Offline johnu
« Reply #1303 on: Apr 13, 2018, 13:59:41 »
Offline teazer
« Reply #1304 on: Apr 13, 2018, 16:55:15 »
Those coils are available from a number of sources.  I believe it's the same coil used by Honda on some of the 360 degree crank twins, or get a DYNA twin outlet coil.  I don't remember what ignition you are using, but with points or DYNA use a 5 ohm coil (and relay) and anything else, use what the ignition system supplier recommends.  And if you are using points, we need to talk........
With a CDI system, typically the coil is much lower resistance and much lower impedance.  For example Economy Cycle sells DYNA low impedance double ended 0.5ohm coils for the RZ.  I have a pair in a box I was about to put on ebay.  I should do that.
Offline johnu
« Reply #1305 on: Apr 13, 2018, 19:46:01 »
It is CDI.
Offline teazer
« Reply #1306 on: Apr 14, 2018, 00:17:07 »
According to a service bulletin, those coils have a primary resistance of 1 - 5 ohms, so I am guessing that any 3-5 ohm double ended coil will work.  I found another reference that says 1 ohm primary and 10K ohm on the secondary side. I'd ask on teh Sundial site, but looks like that Rex's coil might be the easiest one.
One comedian wants 400 bucks for an NOS coil - It's just a coil FFS. https://www.ebay.com/itm/Suzuki-33410-15321-Ignition-Coil-NOS-1976-1977-GT500-Magneto/302700944986?hash=item467a61de5a:g:x4QAAOSwXXVazTBl&vxp=mtr
Offline johnu
« Reply #1307 on: Apr 17, 2018, 17:07:11 »
I just ordered the coil from Rex's.  I saw that one on ebay for $400, that's what made me look for an aftermarket alternative!
Offline CrabsAndCylinders
« Reply #1308 on: Apr 17, 2018, 18:15:01 »
This is one inexpensive solution for your electrical woes.
Lighter, Quicker, Faster.
Offline cxman
« Reply #1309 on: Apr 17, 2018, 18:21:28 »
the bottom must be the 350 amp main fuse
1978 CX650 Super Deluxe
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1974 kawasaki 350 bighorn
1983 GL1100 aspy full dress
1983 GL1100 Nekid
and a bunch of others
