Quantcast
Author Topic: My Suzi T500 Project *It's Alive Video*  (Read 275075 times)
Offline johnu
Re: My Suzi T500 Project
« Reply #80 on: Feb 14, 2011, 19:47:43 »
Finally had some good luck with my project!  My EX650 rear wheel arrived from ebay and the axle size is 20mm which is the same as my YZF swingarm axle.  I can see I will have to machine the sprocket carrier down but at a quick glance that looks to be a cinch also.
Offline johnu
« Reply #81 on: Feb 24, 2011, 21:12:13 »
Not much progress at the moment but I have just started to pull the engine apart.  I assume that one uses a 3 legged puller to remove electronic ignition rotor from the end of the crank (see pic)?  Most that I've dealt with have a thread inside for extraction.  My shop manual only shows the points ignition setup.
Decided instead of paying someone to do my machining I am going use the money to buy a used lathe so that I can do stuff as and when I need it.  Hate paying someone else to do maching.
Offline johnu
« Reply #82 on: Feb 26, 2011, 12:26:50 »
Did a little bit of work on my final drive cover yesterday.  All engine cases will be powder coated eventually, I'm not into the polished cases look personally.
Offline johnu
« Reply #83 on: Mar 07, 2011, 18:43:33 »
Some moderate progress.  Got the engine stripped and the cases painted (looks better in person).  Need to re-plate the crankcase bolts before re-assembling the bottom end.  Also have to get the cylinders ported before painting them (cylinders will be black and heads silver).  Still looking for a used lathe so that I can move forward with the chassis and suspension.
Offline Wingspan
  • Um...what?
    • T500 Build pics
« Reply #84 on: Mar 07, 2011, 19:06:37 »
Looks good. :)
1975 Suzuki T500
2008 Suzuki DL1000
States I've ridden my motorcycle to:
Offline johnu
« Reply #85 on: Mar 08, 2011, 16:23:14 »
Thanks.  I used the same paint as you, the Duplicolor engine paint.  It really goes on nicely and looks good, I just hope it's durable.  Darn sight cheaper than powder coating which I was going to do originally.
Offline Wingspan
  • Um...what?
    • T500 Build pics
« Reply #86 on: Mar 08, 2011, 17:01:50 »
You and me both! I've already managed to put a small chip in one of my heads when I pulled it from the oven.
1975 Suzuki T500
2008 Suzuki DL1000
Offline JoeTee
  • I can't stop going once I've started, it stings...
« Reply #87 on: Mar 08, 2011, 17:27:47 »
Side cases look killer in all black, easier than polishing too.
Joe
1972 zuki GT380 build thread
http://www.dotheton.com/forum/index.php?topic=19528.0
bruuum bum bum babum babum bruuum bum bum babum babum bum babum bruuum bum bum babum babum bruuum bum bum babum babum bruuum bum bum babum babum bum babum bruuum bum bum babum babum bruuum bum babum
Offline johnu
« Reply #88 on: Mar 08, 2011, 19:54:59 »
Well thats a bit of a bummer then!
Offline johnu
« Reply #89 on: Mar 09, 2011, 16:34:43 »
Thanks, my intention is to not have any polished parts on the bike.
