Author Topic: My Suzi T500 Project *It's Alive Video*  (Read 256575 times)
Offline jimmer
Re: My Suzi T500 Project *New Video*
« Reply #1280 on: Sep 09, 2017, 08:09:19 »
Also wondering what kind of cranking pressure do you have?
Yamaha Blaster Bike        Suzuki T500 Titan Twingle
Offline cxman
« Reply #1281 on: Sep 09, 2017, 08:42:07 »
pilots 35 may need a 32.5
no air correct jet to start
2.5 slide
q0 needle jet
6dh4 needle 3rd or so groove to start you may need to go down a size depending on your bike
use a 135-140 main to start
1978 CX650 Super Deluxe
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1974 kawasaki 350 bighorn
1983 GL1100 aspy full dress
1983 GL1100 Nekid
and a bunch of others
Offline teazer
« Reply #1282 on: Sep 09, 2017, 12:21:25 »
I like that needle and jet combo.  Much leaner off idle and similar at 3/4 open up.
Offline johnu
« Reply #1283 on: Sep 11, 2017, 13:38:45 »
2.5 slide
q0 needle jet
Ok i'll try your suggestion for needle and needle jet, thanks.
Bit curious about the main jet size though, pretty much everyone else is around the 260ish size?
My slides are 2.5's :)
Not sure what the air correct jet is?
Offline cxman
« Reply #1284 on: Sep 11, 2017, 16:41:39 »
are you running a single carb?
or twin carbs
a air correct jet goes in the small hole in the intake side at the 6 oclock position
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1983 GL1100 Nekid
Offline johnu
« Reply #1285 on: Sep 11, 2017, 21:35:33 »
Twin carbs
Offline jimmer
« Reply #1286 on: Sep 11, 2017, 21:50:38 »
I really like my single flatslide setup! Now back to our regularily scheduled program.........
Offline cxman
« Reply #1287 on: Sep 12, 2017, 10:10:20 »
i have no idea why you would run a 260 main on a twin carb setup
i dont have anything that big in any of my jetting notes on that bike
i think that flat slide is great thats a 36mm isnt it
i just saw where on f the gp racing guys back in 2008 said he was running 260s but on a gp motor with chambers
seems awful big to me for the street and may simply be that the motor cant approach the draw limit on the jet i dont know
or he was not running pump gas
« Last Edit: Sep 12, 2017, 10:31:02 by cxman »
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1983 GL1100 Nekid
Offline teazer
« Reply #1288 on: Sep 12, 2017, 10:59:39 »
I am surprised how small a main jet is being suggested. Race GT500 carbs I have cleaned have had 230/240 and 260 mains according to my notes.  Interestingly a TD3 or early Tz is typically 280-320, albeit they rev a little higher and are in a higher state of tune.
That suggests that even in a relatively low state of tune, a T500 pulls in so much more air that it creates a stronger signal over the jets.
38mm on a GT750 runs 280-340.  I have seen 210s in 32mm carbs on a 750. Nothing as small as 135.
You have more experience with them than I do, but those are surprising small numbers.  It will be interesting to see what John's bike wants.
Offline cxman
« Reply #1289 on: Sep 12, 2017, 12:04:39 »
you are probably right the notes i have are from 1977 and my memories from there are almost as fuzzy
its probably a mix up in recording the main
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1983 GL1100 Nekid
