www.Moto-Madness.com
Author Topic: Project Shinjimei- 73 TX500  (Read 85504 times)
Offline Jewbacca
  • Therapy is expensive. Riding is cheap. You decide.
Re: Project Shinjimei- 73 TX500
« Reply #390 on: Dec 20, 2015, 03:34:20 »
I really hope this project isn't stalled permanently. I'm in the process of tearing my 74 TX apart and I'm noticing the same issues with mine as yours, so I know what to look for now! LOL. But seriously, did you ever finish her up?
1979 Honda CB750K- Soon to be CB750K-SC Night-Ninja (SOLD)
http://www.dotheton.com/forum/index.php?topic=18771.0
1974 TX500A "Yamahonda" http://www.dotheton.com/forum/index.php?topic=66736.0"
1983 Honda CB650SC
http://www.dotheton.com/forum/index.php?topic=70532.new#new
Gives me a major cramp in my wedding tackle..." Fellow PNW Rocker Dave Simmons
Offline two-smoker
  • I reject your reality, and substitute my own!
« Reply #391 on: Dec 20, 2015, 11:13:28 »
No.... Unfortunately I haven't had a lot of free time since my son was born. Lol. I'm actually considering going to a different engine, even though I bought this beautiful '78 bottom end. I wrecked the '76 head, and I'm not sure if it's worth buying another one. Tri-maha maybe? 😉
"I suppose I'd say.... BOLLOCKS! But that's pretty much a reflex for me."
http://www.dotheton.com/forum/index.php?topic=21144.new#new
Offline two-smoker
« Reply #392 on: Feb 27, 2016, 10:25:33 »
I've decided to sell my Hyosung GT250R to finance the completion of this project. If anyone has an old two-stroke single over 350cc, or a complete but wrecked parallel twin over 450cc, I'd do trades, but I'm not holding my breath.
Offline two-smoker
« Reply #393 on: Dec 09, 2016, 15:19:52 »
Well.... There hasn't been any progress in a while. The bike has been sitting in pieces in my grandma's garage following the breakup between my son's mother and I. With no time or money, or even a place to work, it's been put on the back burner.
That being said, I've got a line on something really unusual for tax time... A guy at work has a couple APU's sitting in his yard, with good engines. (In case you didn't know, APU stands for "auxiliary power unit". They're basically little diesel generators that also run the heat and AC on semis when they're parked up. Saves fuel and wear and tear. Since they don't have to have the main engine idling the whole time.)
The engines in question are 570cc liquid-cooled diesel parallel twins. I'm told they're rated at 28hp. Or the same as my Hyosung 250cc.
But that's without adding a turbo. Sounds like I might be doing something a little unorthodox....
Sent from my Alcatel_6055U using DO THE TON mobile app
« Last Edit: Dec 11, 2016, 23:33:00 by two-smoker »
Offline Jewbacca
« Reply #394 on: Dec 10, 2016, 19:35:50 »
I am on board to see this bastard child come alive.
1983 Honda CB650SC
Offline two-smoker
« Reply #395 on: Jul 03, 2017, 00:26:04 »
http://i961.photobucket.com/albums/ae98/BurnOutSX4/XS500%20project/4725_1.jpg
Alright, here's a picture of an engine like the one I've procured. It's a 2TNV70 Yanmar, for those that are interested in the specifics. I chose this shot to showcase how narrow the motor actually is. Specs say 18 inches wide, 21 inches high, 16.9 inches from front to back. It should fit fairly snug in the TX frame. The reason things are taking me a awhile is I'm trying to figure out what sort of transmission I'm going to be able to use behind it. My first thought was to try and use an aftermarket Harley trans, like a Revtech 6 speed, but I hate Harley's enough (and the prices associated with them) to find that idea distasteful. Perhaps a Norton Commando unit, or something like it.
Sent from my Alcatel 6055U using DO THE TON mobile app
« Last Edit: Jul 03, 2017, 00:37:34 by two-smoker »
Offline two-smoker
« Reply #396 on: Jul 03, 2017, 00:29:26 »
Offline stroker crazy
  • crazy as a fox
« Reply #397 on: Jul 03, 2017, 01:06:01 »
I've seen a couple of attempts to do a diesel conversion; usually lots of torque but not very responsive.
Good luck with it if you go ahead!
Crazy
“Ride like the Wind” W.H.
Offline two-smoker
« Reply #398 on: Jan 31, 2018, 23:21:12 »
Well,  looks like the diesel idea isn't going to work...  I found an Enfield 5 speed trans,  and worked out the dimensions,  but the cost if the tranny and the machine work to mate it to the engine just wasn't worth it....  So I bought a non-titled Honda Rebel 450 for 600 bucks.  I'm working on getting some Chinese-made Keihin-clone flatslides to fit the Honda motor,  and then it's getting shoehorned into the TX chassis.  Most likely with the Honda lower frame cradle.  We'll see.  Onward and upwards!
Sent from my LG-LS777 using DO THE TON mobile app
Offline two-smoker
« Reply #399 on: Feb 15, 2018, 22:43:02 »
It's funny the little things that can hold you up and get on your nerves....  The Honda Rebel 450 came with a 525 pitch chain and sprockets,  and my Yamaha came original with 530 pitch,  which I converted to 520, to match the YZ250 rear hub I used.  Now,  I can't for the life of me get the two to match. I can't find either a 520 front sprocket for the Honda motor,  or a 525 sprocket to fit the YZ250 rear hub..... I might resort to welding my Yamaha front sprocket's teeth onto the Honda sprocket....  But I hope I don't have to resort to that.
