Slipstream Cycle
www.caferacerxxx.com
www.roccitycafe.com
www.oldschoolspeed.com
www.moto-madness.com
www.rustrev.com
Vintage Customs
www.monstercraftsman.com
www.bullitcustomcycles.com
DWMS Racing
Author Topic: CB350 Sly... Ton-less  (Read 15648 times)
Offline DrJ
  • Site Supporter
Re: CB350 Sly... Project dead
« Reply #120 on: Jun 17, 2012, 23:39:07 »
Wouldn't the sleeve push down and level when you torque the head? Or place the cylinder upside down on a hard, level surface, then use piece of wood and hammer and pound the sleeve back in.
« Last Edit: Jun 17, 2012, 23:40:41 by DrJ »
Offline surffly
« Reply #121 on: Jun 18, 2012, 00:06:59 »
When the cylinder is cold you should not try to move the sleeve.
when hot it will slide with out much effort
Offline overdraft
« Reply #122 on: Jun 18, 2012, 00:22:25 »
thanks guys! sonreir put me on to heating it up... torquing cold did nothing... in the oven as we speak! I'll keep you posted!!!! there may be hope yet!
ceebeetreefiddee... here's my li'l build thread... http://www.dotheton.com/forum/index.php?topic=21812.0
Offline crazypj
  • Site Supporter
« Reply #123 on: Jun 18, 2012, 00:34:51 »
I hope you had a couple of wood blocks ready and welding gloves to lift it out of oven, if you stand it on spigots they will slide up further
Usually needs around 350~400f, I've done a LOT of big bore/liner changing  ;) 8)
I gave my girlfriend an orgasm the other night, but, she spat it back at me
Offline deepwaterimports
« Reply #124 on: Jun 18, 2012, 00:50:08 »
great looking build mate would love to folow this one
Online teazer
  • Site Supporter
« Reply #125 on: Jun 18, 2012, 01:52:58 »
That tends to happen with Honda barrels if the sleeve interference fit is a little on the light side. We have had a couple that happened to.
If you want a laugh, put a spare set of Honda twin barrels out on your driveway on a really hot day (right way up) and check them after an hour or so. Chances are the liners will be moved a long way. Sometimes they will fall out.
You can guess how I made that discovery. :-(
Offline overdraft
« Reply #126 on: Jun 18, 2012, 02:02:09 »
thanks for all the support everyone! it looks like we got the fix on this problem, subject to final inspection tomorrow when it's cooled down. i was freakin' out a bit! ok, a lot! update tomorrow!
Offline crazypj
  • Site Supporter
« Reply #127 on: Jun 18, 2012, 02:50:09 »
LA Sleeve recommend 0.004" interference but I find that's too tight so use 0.003"
Awful lot of earlier Honda's only had 0.001"~0.0015" interference (I've measured quite a few)
Offline ducatiboy
Re: CB350 Sly... Project possibly back on track
« Reply #128 on: Jun 19, 2012, 10:13:59 »
Great job on this build OD! :)
Just another CB350 cafe (current project) http://www.dotheton.com/forum/index.php?topic=32827.0
In the garage:
Ducati 848 Road bike
Ducati 848 Track bike
Ducati 750 F1 x 2 (next 2 projects)
Honda XL 185 paddock basher (complete)
Honda XL 185 Paddock basher (in pieces)
Offline overdraft
« Reply #129 on: Jun 19, 2012, 11:15:35 »
well, the liners did slide ALMOST back into place when i heated them up. i tried again with a different jig so there would be more weight on them and it got a bit better but they're still up by .004" at the high spots. does anyone know how much irregularity a head gasket can tune out? am i close enough to make it up with gasket goo?
thanks again for the support.
Offline crazypj
  • Site Supporter
« Reply #130 on: Jun 19, 2012, 12:45:53 »
They will drop when engine gets hot so you will probably need to re-torque head after first run.
 The alloy shrinks further than the cast iron so you chill top of cylinders while hot, I use an old baking tray full of ice so top of block will cool before bottom, I also made a fixture to clamp liners on the XS650-800 conversions I've done
Offline overdraft
« Reply #131 on: Jun 20, 2012, 02:55:02 »
ok, both liners are out. i thought maybe there was some crap in the seats that was keeping the liners up that extra 4 thou, but no. so now i have to decide if thats close enough or if i should be trying to get the liners trimmed. i dont really want to do a bunch of unnecessary work if the gasket will take up the .004" difference, but i dont want a motor that weeps oil constantly either... and meanwhile i scorched and discoloured my engine paint, so i have to go back to the blaster and repaint as well...
« Reply #132 on: Jun 20, 2012, 09:06:32 »
damn this is one good build!!! Love those rearsets!
.........raised on 2 wheels!!!
1969 CB350 cafe
http://www.dotheton.com/forum/index.php?topic=24448.0
Offline surffly
« Reply #133 on: Jun 20, 2012, 11:36:32 »
damaged the paint?  you didnt use a torch did you?
uneven heat is a really bad idea
400* in the oven for a while then literally tap them into place, job done
Offline crazypj
  • Site Supporter
« Reply #134 on: Jun 20, 2012, 12:49:12 »
 DO NOT SHORTEN LINERS
They WILL move when engine gets hot and they are under pressure, then they will leak.
'Liner drop' is pretty well know by people who do big bore/liner swap conversions
I've only ever had one drop far enough to cause problems which is why I made fixtures to keep pressure on liner while cooling
