Re: Moto Guzzi V50 II Cafe
I started working on the tank, doing a mod to replace the huge ugly plastic fuel cap cover with a metal LeMans replica cap. Ill post this up when done.
The other thing I need to do was work on the front fender...
The bike came with a plastic fender (red, left), and amongst the spares that came with the bike when I got it was this steel fender. So, firstly, the steel fender can be cut down and I can roll the edge to make it look good, as opposed to cutting the plastic, and the mounting bracket is also pressed steel, which, when bolted into place forms a rigid body, making the forks more rigid... Am I right? This to my mind is a performance upgrade? Had it powdercoated.
So if you look at my concept image, the fender is cut down substantially. Its not meant to be functional. Its an aesthetic component for the most part...
In my drawing here, its also super snug on the tire. I *do* actually want this, - - the stock bracket used lifts the fender about an inch off the tire. Easy enough to drop it by making new holes, I'll see later, when the fender is fitted...
So from a visual perspective, I wanted the leading edge of the fender to start at exactly half way on the wheel, perpendicular to the ground...
Measured it up.
I wanted the side I cut down to match the other side, so made a template by wetting a piece of paper and wrapping it around the end I wanted to emulate...
When dry, I had a paper replica to trace off from...
Cut.
Roll.
Tweak.
Done.
Its going to be painted, so the small marks and beating will easily be sorted with some light filler...
A nice quick job, but another tick off on the to do list....
