Author Topic: CB350/360 starter block off plug, speedo spacers, tach plugs  (Read 44461 times)
Offline crazypj
Re: CB350/360 starter block off plug
« Reply #70 on: Jan 22, 2012, 12:10:05 »
Hi All,
There seems to be confusion with some people how the plug fits.
 I assumed it was self evident as anyone working on their own bike would be mechanically inclined(doh,shouldn't make assumptions)
Anyway, here's the 'ded' CB350 case I use to check they fit properly
1. From the outside, not fully pushed 'home' as it's only there for pics
How it looks from the outside
2. From the inside, turn plug to get screws in best position.
 It will work with only one screw but I like things to be symmetrical (some motors can only use one screw, there are variations in cases) When permanently fitting, I like to smear some sealant around plug and also Loctite screws in position.
The 'O' ring prevents dirt/water getting into the opening so it can be removed if you want to re-fit electric starter in the future, if it was moved further in you could get corrosion in there which could damage bore.
I forgot to mention, if you have corrosion in bore from stock starter motor, you need to clean it out with scraper/emery cloth/sandpaper or whatever
 It doesn't need any cross pieces, the screws only need to 'overlap a few thousandths on an inch to stop it falling out
I don't know what happened to pictures, they were still on photobucket.
I've reloaded them on post
« Last Edit: Jan 07, 2013, 23:32:38 by crazypj »
Best thing I ever overheard
Brian Morgan, 1982
Offline crazypj
« Reply #71 on: Jan 26, 2012, 01:09:59 »
Hi All,
 Don't know if your aware of it, but, USPS prices increased last Monday (23rd Jan)
 It's not too bad at present so I'm keeping postage at 'old' rate until next price rise (or they close local post office and I have to travel further  :( )
Brian Morgan, 1982
metropolitanhighrise
  • Guest
« Reply #72 on: Jan 26, 2012, 04:10:58 »
Hey PJ,
The plug arrived just today.  I couldn't be happier with it!
Offline crazypj
« Reply #73 on: Jan 26, 2012, 13:05:40 »
Great, glad you like it
Thanks for lettig me know you got it  8)
Brian Morgan, 1982
Offline MB
« Reply #74 on: Feb 27, 2012, 19:56:31 »
Hey PJ, wanna turn out one for the 450?
Offline crazypj
« Reply #75 on: Feb 27, 2012, 22:05:51 »
They fit 450 and 500T  ;D
Brian Morgan, 1982
Offline crazypj
« Reply #76 on: Apr 03, 2012, 19:47:57 »
I think I've got everyone covered on starter plugs an sync adapters.
PM me if you need info.
Dave, yours is on it's way to Canada
Brian Morgan, 1982
« Reply #77 on: Apr 03, 2012, 22:47:04 »
cant this be installed with motor on frame? i know it needs to be screwed from the inside, but whats involved in the install from a motor on frame, running bike stand point?
'73 cb350
'82 xv750
Offline SONIC.
« Reply #78 on: Apr 03, 2012, 22:55:26 »
Yes,
Drain oil, Pull the side cover, pull the starter, put in plug. put side cover back on, refill oil.
Enjoy
« Reply #79 on: Apr 03, 2012, 23:10:02 »
nice, gotta do an oil change anyway... so can i still get one?
'73 cb350
'82 xv750
