Author Topic: CB350/360 starter block off plug, speedo spacers, tach plugs  (Read 45595 times)
Offline crazypj
Re: CB350/360 starter block off plug
« Reply #80 on: Apr 04, 2012, 05:44:08 »
................................remove starter chain and starter motor sprocket, would probably be a bit noisy if you left them in there  ;)
Best thing I ever overheard
Brian Morgan, 1982
Offline FishBoyRacing
« Reply #81 on: Apr 23, 2012, 02:06:07 »
Hey man... Do you have anymore of the starter block off plugs..? Nice gear man... '69 CL 350 K1
Let me know, Thanks...
Union Jack Moto Co
Offline crazypj
« Reply #82 on: May 04, 2012, 01:03:11 »
Hi, did you PM me and get a plug?
Brian Morgan, 1982
Offline SONIC.
« Reply #83 on: May 05, 2012, 18:25:08 »
Yeah yeah  8)
should have said "all starter components" haha
Ill be needing one of these eventually
Offline crazypj
« Reply #84 on: May 14, 2012, 21:33:30 »
I made more shiny bits.  ;)
Neevo wanted a speedo drive eliminator spacer so I made an extra one
It's for CB360 but will fit 350 and 400f if you can either run without speedo or are using an electronic one so don't need speedo drive on hub
Here's pics
And what they look like unpolished
Brian Morgan, 1982
Offline Nasty N8
Re: CB350/360 starter block off plug, speedo spacers, tach plugs
« Reply #85 on: May 23, 2012, 13:12:45 »
Got mine everything off to the anodizer. Thanks man
Offline crazypj
« Reply #86 on: May 23, 2012, 21:00:40 »
It's all 6061-T6, untreated, (just in case he needs to know)
Brian Morgan, 1982
Offline Flying J
    • Flying J Customs
« Reply #87 on: May 26, 2012, 18:05:51 »
would you be interested in making a tach block off plug for a cb550? Something like this.
Offline crazypj
« Reply #88 on: May 26, 2012, 20:18:59 »
 I already make speedo/tach plugs but I don't make them like that
 I make mine different so weather/water cant get inside
'O' ring is just under flange.
They will fit 550 as it's pretty much same set up as 360
I also make them so you don't have to remove cam cover to take the drive gears out so I guess mine are far superior ;D
I don't have any pics of latest version, they use a smaller 'O' ring that works with flat and countersunk cam covers. They even fit CB/CM400T  with slight modification to flange
This was the MkI version that needed the drive gear removed, made it 3~4 yrs ago
« Last Edit: May 26, 2012, 20:37:38 by crazypj »
Brian Morgan, 1982
Offline facefirst35
    • My Portfolio of merchandise design
« Reply #89 on: Oct 17, 2012, 19:32:30 »
Any chance of the starter plug fitting on a CB/CL 175 motor?
