i like would like to use some of your ideas just wondering how you went around doing them appreciate any pointers on 1993 GSXR 1100 Forks with Racetech Springs, 1993 rear wheel assembly and the Dynojet Stage 3 kit with K&N Pods also where did u purchase the stage 3 kit with k&n pods thanks
I got the kit from Ebay, as it isn't sold in Canada.
As for the forks, they are the longest of all GSXR forks, and will bolt right into the bike, as long as you use the original GSXR trees. It really is a straight foward swap, but you need to swap to the rear rim, as you will be running modern rubber with this. Also, the chain needs to be re-aligned so to clear wider wheel. that's the toughest part, as you need to get an offset sprocket, and then make sure your chain is lined up correctly.
