Author Topic: 71 CB350 Project (Sold!)  (Read 35563 times)
Offline jonnyTHUNDERmaker
Re: 71 CB350 Project
« Reply #10 on: Feb 22, 2011, 13:02:15 »
Some pictures of the gas tank. Still needs a good strong clear coat.
Anyone have any recommendations for a very strong clear coat?
Also, I need a new front tire. 18-3.00 Any specific tires I should look into.
Need a new chain
I dont want to spend a lot
Thanks all.
Offline VonYinzer
« Reply #11 on: Feb 22, 2011, 16:45:56 »
http://www.spraymax.com/index.php?id=361&L=1
You can get nice Shinkos from Motorcycle Superstore for around $50.
Spend as much as you can on the best chain you can find.
Paint looks cool man. Good bit of orange peel though. Looks like it needs some more wet sanding to smooth it out before clear.
« Reply #12 on: Feb 22, 2011, 18:36:41 »
Thanks,
Well the orange peel on the tank is supposed to be there. I used Rustoleum Hammered. It gives an orange peel texture, its pretty cool. The problem is that the black stripe is kind of wrinkled. Any idea on how to fix that.
Also thanks for the advice. Is this the tire I need? http://www.amazon.com/Shinko-Tour-Master-Front-Tire/dp/B001CDALP8
« Reply #13 on: Feb 25, 2011, 14:47:16 »
Hey all,
I got my carbs in finally. Mikuni Vm30's. I know I need to make some intake adapters. I there any good place to how to hook these all up.
I am assuming I need a 2-1 throttle cable is this right. Any other info would be great.
Thanks
Offline El Granto
    • ElGranto.com
« Reply #14 on: Feb 25, 2011, 15:58:30 »
Great idea on the Skateboard! I'll be watching to see how it finishes up!
« Reply #15 on: Feb 25, 2011, 16:06:22 »
Thanks, I got it all mounted up last night. So far it looks like its going to work out pretty sweet. I really like how the back fins up.
I am planning on putting my tail light right underneath the fin. Just have to find a small bright LED taillight for cheap.
Offline Danish_Cafe
« Reply #16 on: Feb 25, 2011, 18:16:17 »
This build is looking good, I like your ideas and will be following!
« Reply #17 on: Feb 25, 2011, 19:39:41 »
Hey guys,
I found these flange mounts for the carb side, and have the ones already on the engine side. Now I just need to find a tube to squeeze in both sides.
http://www.amazon.com/Mikuni-Rubber-Flange-Typical-990-842-046/dp/B003CJQOEC
Offline B L A K E
  • "Against All Odds".
    • My build thread
« Reply #18 on: Mar 01, 2011, 22:22:21 »
Wait you can put a small battery like that on there? how can that be?
Offline VonYinzer
« Reply #19 on: Mar 01, 2011, 22:47:46 »
For the cable, order one for a 68 cl175.
