www.Moto-Madness.com
Author Topic: DIY Aluminium café tank possible?  (Read 17585 times)
Offline Gordon
    • Cafe Racer Projects
« on: Nov 22, 2007, 07:12:35 »
I'd like to try my hand at building a simple aluminium motorcycle cafe racer tank for my Royal Enfield. Need help on the following:
  • What guage sheet?
  • How do I weld? I've heard aluminium is difficult to weld. I know of someone who can do "electric welding".
  • How do I ensure that there is no leak?
  • Mounting points?
  • Does anyone have drawings that I may use to cut the sheet?
  • Please add in any other relevant information.
I've never done this before. This is all new to me, but I somehow imagine it can be done.
Don't know if I've posted this earlier. Anyways please help me as always.
Gordon
Offline Gordon
Re: DIY Aluminium café tank possible?
« Reply #1 on: Nov 22, 2007, 07:53:54 »
This is what I'm looking out for. The red one is more appropriate ;D
Gordon
Offline derant
    • JET FUEL MOTO
« Reply #2 on: Nov 22, 2007, 09:11:00 »
I noticed that you posted this info at MetalMeet, which is a good place to search for this info.
Anyway, to answer some of your questions:
What guage sheet? 3003 AL around .063 (16 gauge I believe)
How do I weld? Two choices, gas or arc welding (TIG). Welding AL can be tricky. It is very easy to blow through because you have to use a lot of heat and move quickly...not to mention trying to keep track of the puddle.
How do I ensure that there is no leak? When the tank is complete, pressure test it by capping all openings (petcocks, fuel filler) and injecting low pressure into tank will submerging tank in water. Existence of bubbles indicates pinhole leaks.
Mounting points? Those wil have to be fabricated to fit the mounting on your frame.
The first thing you need to learn is how to metalshape. You need some simple tools to do that. The most basic tools you need are a hammer, sandbag and a hollowed out wood stump.
Go to the MetalMeet site and do a search for 'getting started with metalshaping' or something similar.
To do a tank like the ones indicated, you need a buck to reference against. Do a search on MetalMeet for 'making bucks' and 'flexible patterns'.
What you're attempting to do isn't easy, but it can be done.
I speak for experience because I have made a gas tank for a motorcycle, and am currently making another one for a Cafe style bike.
Offline Tim
  • Administrator
    • DO THE TON
« Reply #3 on: Nov 22, 2007, 21:41:44 »
I'd start with a panel sided tank, basically just flat sheets welded together at the corners.  You could easily taper one end with simple bends in the metal, but without complex forming.  Something like a Honda CR750 style breadbox tank (which I happen to love).  No nonsense functional tank.
One day I want to learn to weld, but frankly for the costs involved in the hardware setup, I can't justify it at the moment.  I spend about $300 on having pros do all the welding I needed done on my 650 project, including materials.  I'd have to do a few projects to get the equipment paid for.  Granted I'd have the satisfaction of doing it myself, but I don't think I'd trust my welding skills on my motorcycle frame :)
Offline Gordon
« Reply #4 on: Nov 29, 2007, 00:00:21 »
Okay forget the aluminium tank for now. Lets just concentrate on normal sheetmetal :-[
I was just thinking how I'd have to cut the sheetmetal in order to make a simple tank that resembles the above red tank. This is what I could come up with. It doesn't have a lot of curves.
The below pic is a rough design. Its only of the top and side parts of the tank. Black lines indicate where I have to cut. Lightblue area will be overlapping to create the round shape in the front.
  • Should I go ahead and make a miniature tank first?!
  • Are any changes required?!
  • Or is the drawing just crap and NONSENSE and its not possible to make a tank with this design?!
« Last Edit: Nov 29, 2007, 00:09:48 by Gordon »
Gordon
Offline derant
    • JET FUEL MOTO
« Reply #5 on: Nov 29, 2007, 10:14:35 »
While that cut pattern you posted may work, there are better ways to accomplish what you want.
I would suggest that you make a full-sized buck of your tank. This is the buck for that tank I am building:
From the buck you can make a flexible pattern, that along witht the buck will help you to quite accurately shape your desired tank.
Here is some of my metalshaping progress so far on my tank:
Offline Tim
  • Administrator
    • DO THE TON
« Reply #6 on: Nov 29, 2007, 11:42:22 »
That's impressive - is it the left side so far you've done, or does that extend down the right side too?
Offline derant
    • JET FUEL MOTO
« Reply #7 on: Nov 29, 2007, 11:49:05 »
What is pictured is just the left side. I have started working on the right side and have the basic shape achieved like the left.
The next steps are to carefully stretch the sides to fit tightly to the buck...and then create the tunnel and the knee cutouts.
Offline Gordon
Wow! Thats very well done!!
« Reply #8 on: Nov 29, 2007, 12:51:39 »
Quote
Quote
That's impressive
I agree. That is very impressive. I would love this shape, but then I don't know how to curve the tank and I do not have the experience and expertise in such advanced metal working.
Which is why I opted for the less curvy tank to start with. Moreover, I also have no woodworking tools and experience to make a buck. I know I'm jumping into an unknown area and trying to create a tank without a buck :o If it gets too complicated I'll hire an experienced helper.
  • What guage sheetmetal did you use?!
  • And how big was that sheet?
And the most important questions:
  • Will the above layout work?! Yes/No
  • Does anyone have an alternative layout?! Or a drawing of how I'd need to cut the sheet?!
Gordon
Offline derant
    • JET FUEL MOTO
« Reply #9 on: Nov 29, 2007, 13:09:19 »
Gauge of sheetmetal = 18
Size = 2 pieces approx 15" x 25" each.
The layout you posted probably will not work to achieve the tank style you want. If you want more of a breadbox shape, something Tintin pointed at earlier, than yes you may be able to use it.
The red tank that you want to make, even though it isn't as curvy as the one I am building, it still has low crown compound curves...picture a shallow bowl. The only way to achieve compound curves is to metalshape (stretch the metal by hammering into a stump and/or sandbag).
