Slipstream Cycle
www.caferacerxxx.com
www.roccitycafe.com
www.oldschoolspeed.com
www.moto-madness.com
www.rustrev.com
Vintage Customs
www.monstercraftsman.com
www.bullitcustomcycles.com
DWMS Racing
Author Topic: *DONE* Road Pig build : for Joey cocks forum member (vid and pics at close)  (Read 4387 times)
Offline JRK5892
  • Site Supporter
    • The Powder Pro
Re: Road Pig build : for Joey cocks forum member
« Reply #30 on: May 02, 2011, 17:11:20 »
rest of the big stuff in gloss black is done, the light bar, headlight cover, lights, trim rings... good to go on gloss black. have texture black to shoot next roudn then powder is all done...
got to wire up the light bar and new front turn sigs now
Joe
"your life is an occasion, Stand up to it"
www.thepowderpro.com
recent builds: Hd street bob, TX cafe, KZ bratt, Goldwing tour, bratt wing, st fighter, road king, vriago bobber, chop, FXD, 1200 sporty, 1200xl sporty, GSXR, Royal enfield.. and more
Offline JRK5892
  • Site Supporter
    • The Powder Pro
« Reply #31 on: May 02, 2011, 17:11:40 »
ooh ya all the bolts and nuts are coated as well
Joe
Offline my94f2
« Reply #32 on: May 03, 2011, 08:52:21 »
yummmm fresh pc
i dont need sex. life screws me when it can
Offline JRK5892
  • Site Supporter
    • The Powder Pro
« Reply #33 on: May 03, 2011, 13:33:52 »
pulled the lowers apart again and put in the new top out spring... also cut a .5 spacer to preload the shock to stiffen it up a bit to ensure that fender does not bang, this is internal so it will not effect the ride height, and should help with dive in turns
went with a Type E fork oil, thick and heavy duty
pulled off the stock 2 disk brake line, rebent and routed a single brake line
made a clip and drilled it so i could tap it under the tree to keep things clean
rotor bolts Before
after the buffing wheel had at them
rotor on and wheel in place
spacers are way way way off... DNA of course does not sell them... may have to go into the machine shop to make my own. Gonna contact my buddy mitch to see if i can use his lathe to turn them down. they are too short to fit in my gravity saw, and too much material needs to be removed for me to turn them on the belt sander...
Joe
Offline troybilt
  • Site Supporter
« Reply #34 on: May 03, 2011, 14:18:09 »
Very cool Joe. Beautiful work as always. I like the clip under the tree. Not sure why I've never thought of that. I'll def. be stealing that idea for sure...Hope you don't mind
"she's really pretty. Here's five bucks. Play Justin Timberlake." Doug Kiggins
Life Begins At The End Of Your Comfort Zone
“There are hundreds of paths up the mountain, all leading to the same place, so it doesn’t matter which path you take. The only person wasting time is the one who runs around the mountain, telling everyone that his or her path is wrong.”
— Hindu Proverb
Offline JRK5892
  • Site Supporter
    • The Powder Pro
« Reply #35 on: May 03, 2011, 14:20:12 »
steal away brother steal away! hope i can get on the lathe this week some time to get them broke down to size... slap the headlight cover on, new rubber on back, then jut have to coat the floor boards and controls and she is done! have big plans for my bob again so i hve to get moving!
plus i think i am going to buy wifey the new sporty 48' so i could use the extra $ aas well! hahahaha
Joe
Offline HK_Sailor
« Reply #36 on: May 04, 2011, 09:39:41 »
All the powder and the massive front wheel look great!
I actually really like the way the front end looks!
1989 Yamaha XV250
1999 Honda Steed 400
1976 CB360T
Offline JRK5892
  • Site Supporter
    • The Powder Pro
« Reply #37 on: May 10, 2011, 14:02:21 »
getting there, front end about buttoned up, just spun the new spacers on the layth so i can install them
6 piston looks tuff!
pulled the rear wheel
installed the new tire and cleaned up the rim
swapping a new brake line that ran dot 4 so i removed and flushed the master with denature alch so no issues as well as all the lines
Joe
Offline zero
« Reply #38 on: May 10, 2011, 14:57:32 »
That front caliper looks badass! Are you going to run fat spokes in the back too?
Offline JRK5892
  • Site Supporter
    • The Powder Pro
« Reply #39 on: May 10, 2011, 14:59:46 »
no point... we are swapping to extended hard bags, you will never see it. be a waste of money with the reg spokes you will never know the diff
Joe
Offline JRK5892
  • Site Supporter
    • The Powder Pro
« Reply #40 on: May 10, 2011, 19:51:26 »
cutting the spacers
Joe
Offline JRK5892
  • Site Supporter
    • The Powder Pro
« Reply #41 on: May 12, 2011, 11:39:53 »
alright!
got the new rubber on and put in the rear wheel, alligned the belt and got that all squared away... removed the stock shocks with lowring blocks (they blow out after a few hundo miles) and replaced them with 12 in air shocks to to get the 1 inch drop in back
front wheel spacers in and cut perfect!
front fender inplace and bolted down, wheel done up front... now thats how you do a fatty spoke 21
Joe
Offline JRK5892
  • Site Supporter
    • The Powder Pro
« Reply #42 on: May 14, 2011, 12:25:40 »
took the bike off the lift to run a shake down to test everything out... rides great! have to say very impressed, well worth the extra work to get the soft ride that a touring bike should have... the 140 tire up front is awesome! now to button of the front lights, and then pull off the foot controls to black those out with graphite black
Joe
Offline CrescentSon
« Reply #43 on: May 15, 2011, 10:59:14 »
Exquisite work as usual Joe. Those wheels make the bike brother.
"I hated hipsters before it was cool." -Sonreier
"Lifes a bitch when your trying to sell gold bars to beggars" -VonYinzer
"To say that ALL cafe racers are the same degree of ho hum is like saying that finger banging a fisher price piano is on par with listening to Beethoven." -Kanticoy
Offline zero
« Reply #44 on: May 15, 2011, 11:59:08 »
I cant wait to see the ext bags on there..
