Slipstream Cycle
www.caferacerxxx.com
www.roccitycafe.com
www.oldschoolspeed.com
www.moto-madness.com
www.rustrev.com
Vintage Customs
www.monstercraftsman.com
www.bullitcustomcycles.com
DWMS Racing
Author Topic: CB550f 1976 back from the dead project.  (Read 7176 times)
Offline RustyOlive
    • http://rustyolive.com/
Re: CB550f 1976 back from the dead project.
« Reply #30 on: Dec 23, 2011, 12:12:56 »
I some what agree with you.
If our bikes were going to hit a track or fly down the hi-ways wide open... Which even on a good day on my 550, is pushing it beyond its factory-breaking point.. Hahahaha. Then, maybe i'll pay more attention to rake. But seeing as my bike is mostly a city booter and hitting the back roads in the country side from time to time. I'm sure its all good...
Plus, I've already changed so much in my bikes genometry, its never going to ride like the same old CB550 that rolled off the floor in 78.. Hahaha.
image by RustyOlive, on Flickr
Offline Bert Jan
  • Holy Modification Batman
    • Outsiders Netherlands
« Reply #31 on: Dec 29, 2011, 22:09:09 »
my thoughts exactly ;)
there;s one thing i need your (all of you) opinion about. funjimmy's adapters have rings to fit in the hub. for allignment and stiffness and such. i dont on one side. the 6 8mm 8.8 bolts are everything holding hub and bearing together. There's a little edge, about 3 or 4 mm that centers the adapter though. i hope it's clear, cant explain it any better.
are the 6 bolts strong enough?
chopped the bolts a bit btw, wheel is spinning free right now. ordered brake lines and worked on the throttle.. few more weeeeeeeeks!
http://outsidersnl.wordpress.com/
Swagger: 'Anything we did for Uncle Scam or Nasa was soldered, period. No crimps allowed.'
Offline Bert Jan
« Reply #32 on: Jan 09, 2012, 18:16:01 »
small update to avoid the 30days whining... Installed braided brakelines.
working on my gf's cb200 most of the time i have off.
Offline Bert Jan
« Reply #33 on: Jan 10, 2012, 12:23:16 »
Today i bleeded the brakes and found out my clutchline is shot. Came between fork stopper thingy damnit. another $40 down the drain. Hope to make it fit on my gf's clutch or brake for the cb200 cause the line is broken near the banjo.
brakepads are against the discs, causing a drag. Will this dissapear when riding or do i need to clean em up. It's not THAT bad, i can still push the bike without to much effort.
Offline Bert Jan
« Reply #34 on: Jan 23, 2012, 11:58:19 »
Been very busy with school and my gf's cb200 engine. That thing is gonna be awesome :)
Did a little tinkering on a taillight i bought. I think it's to big for a taillight. Instead, i'm going to use the housing to accomodate my speedometer and ignition lock. Odds are they are EXACTLY the same in diameter!
Removed all the little bits 'n pieces. Just speedometer, oil and neutral lights. No tacho either.
the lighter is in there to keep the meter straight...
Going to take care of the inside of this thing on the lathe, so it will become a ring to lock up the speedometer.
end result (planned), without the ring on it obviously.
next to being a perfect fit it's a rigid lump of metal, so ideal for my ignition lock and wiring shizzle.
Also fixed my front brakes (calipers came without mounting bolts, 10x1,25 is damn hard to find here in the Netherlands..)
Like i said i have been doing massive engine work on my girl's CB200. I guess she will be updating lots-o-pics tonight or tomorrow.
Offline Bert Jan
« Reply #35 on: Feb 05, 2012, 17:23:28 »
just bought myself some sweet bluespot 4 piston calipers cause the costs were even between that or revision kits and such.
Gonna look killer :)
Not much news.. 3 months till graduation, so busy wih that most of the time..
I also found out i can still use the original tacho cause i used the "original hub" part. Have to check the speed though and adapt the tacho plate with the numbers. Easy,i have that open already. life's gooooood!
Anybody know where i can find info regarding the scale on the tacho without using a GPS and marker alongside?
Some formula or both the rev numbers from the cables? YZF750 94' vs cb550f '76
« Last Edit: Feb 05, 2012, 17:32:31 by Bert Jan »
Offline Bert Jan
« Reply #36 on: Feb 07, 2012, 06:29:31 »
gonna slap em on this afternoon. Heard somewhere they won't fit without modifing the fork legs?
Offline Bert Jan
« Reply #37 on: Feb 16, 2012, 09:14:07 »
Mounted the calipers today. Forks needed to be filed (not sure about if that's the correct word..) but it's all good now. they clear the spokes by about 2mm. Enough :)
Seat and rear fender building will be done in coming week. very busy with school/
Offline Bert Jan
« Reply #38 on: Feb 18, 2012, 10:48:39 »
update:
new clutch hose, calipers mounted and bleeded, rear fender in mock-up and working on the seat.
used FunJimmy's idea on the fender. The mounting part got chopped and i removed a large piece from between the fender. Then welded them together again. Will get some resin over it to smooth it out.
Pics:
Wood? wtf?
Determing center:
Skwweekkkk skwweeeek skweeek (you know, when a tool made for wood is used on aluminium ;))
Swing!
« Last Edit: Feb 18, 2012, 16:23:48 by Bert Jan »
Offline Ringo
  • Site Supporter
« Reply #39 on: Feb 18, 2012, 12:23:45 »
Very slick!  Mind telling a little more about your hydraulic clutch swap?  I've been wanting to do that.  The one I've been eyeing basically just replaces the cable:
http://www.ebay.com/itm/150758011347?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Offline Bert Jan
« Reply #40 on: Feb 18, 2012, 16:05:33 »
Hey Ringo, thanks! In my first post, 4 pages back, is a link to my build when i came to this forum. I made a new topic. dunno why actually :P Here:
http://www.dotheton.com/forum/index.php?topic=26406.0
Offline Bert Jan
« Reply #41 on: Feb 18, 2012, 16:33:40 »
Seat made from 18mm waterproof multiplex:
I've asked ALOT of times on the forum how to do seats, not that much responses so i just started. turned out ok i guess. gonna fit it tomorrow and we'll see from there.
I first made a rough model with scrap wood and painter-tape. Wrote down some measurements and used that to make a solid underpan from the multiplex. Planning on using hard foam to make the seat give it's final shape and then some softer foam for covering. Already have a fabric to go on top. Salvaged and old chair and using the seat-fabric. Has lines and everything already sewn in! Using wood because it's easy to work with and because i can nail the seat to it, wich Impossible with sheetmetal.
Weapons of mass destruction:
« Last Edit: Feb 18, 2012, 19:03:14 by Bert Jan »
Offline Ringo
  • Site Supporter
« Reply #42 on: Feb 18, 2012, 18:52:48 »
Ah thanks mate!
Offline Bert Jan
« Reply #43 on: Feb 18, 2012, 18:56:58 »
Will flatten the 2 little pieces in the first bend. They're primarily there to help the contraption dry in the right angle. Plan is to mount some heavy steel bar (5mmx50mm) across the length of the seat with bolts, and touching the wood everywhere. That will give it enough strength to ride 2-up and i'll have something to attach my hinge on.
There are little pieces of round-wood at the angles, they're called "duvels" in Dutch. They help a lot to for strength too.
Also using some water-hose cut in half lengthwise across the edges of the seatpan to protect the foam and fabric from the hard and sharp edges. Guess it will be a little more comfortable as well.
« Last Edit: Feb 18, 2012, 19:01:47 by Bert Jan »
Offline Bert Jan
« Reply #44 on: Feb 18, 2012, 18:59:40 »
Ah thanks mate!
np, your le mans is the reason i found this forum, so happy to help you out! How's the cb200 doing? finished yet? :p
